Old 01-03-2004, 11:53 PM   #1
j{}n
j{}n's Avatar
j{}n is an unknown quantity at this point
Send a message via AIM to j{}n Send a message via MSN to j{}n
what was that website that had turbos made specifically for the 2.4L alero? i believe they had a pic of silent's car with the *** kit on that specific page. thank you to anyone who helps :thumbsup:
'05 mazda 3
zoom zoom biatch
j{}n is offline   Reply With Quote
Old 01-04-2004, 12:05 AM   #2
Oldsman
Owner
Oldsman's Avatar
that was exploited racing
http://www.exploitedracing.com/
Beware of the BackStabber
Old 01-04-2004, 02:44 PM   #3
aleropimp1
hey if i just got a turbo manifold would it give me any horse power or do i need the kit
Old 01-04-2004, 05:10 PM   #4
j{}n
j{}n's Avatar
wait, do they not make it for the alero anymore?
'05 mazda 3
zoom zoom biatch
Old 01-04-2004, 05:20 PM   #5
AnderbrA
AnderbrA is an unknown quantity at this point
Send a message via MSN to AnderbrA Send a message via Yahoo to AnderbrA
turbo mani is to attach the turbo...so yeah you need the kit.
AnderbrA Innovations
Custom Automotive Lighting
www.anderbrainnovations.com
07 Cadillac STS V8
07 Mitsubishi Galant ES
00 Olds Alero - Parts
02 Lincoln LS V8 Sport - RIP
AnderbrA is offline   Reply With Quote
Old 01-04-2004, 11:07 PM   #6
Oldsman
Owner
Oldsman's Avatar
the cav kit will fit. he just redid he website
Old 01-08-2004, 12:41 PM   #7
mrpute
Check out this thread for pics of the 2.4 LD9 manifold:
http://www.j-body.org/forums/read.ph...=31310&t=31310
I just purchased a 2.4 manifold for my Cavalier and an Ecotec manifold for my Alero from Exploited Racing. The quality of the them is absolutely amazing. Brian who owns Exploited has been in the business for almost two years now. His first batch of manifolds ever made were horribly welded and were fabricated out of cast iron conduit. The new manifolds I believe are MIG welded and use marine grade stainless steel. Since Brian has been doing this for two years now, his welding abilities have vastly improved. Lots of guys in my j-body club have Brian's manifold and have not seen any problems develop with them.
Old 01-09-2004, 12:40 AM   #8
Oldsman
Owner
Oldsman's Avatar
actually Brian, TIG welds them now. a lot better weld. stronger and less warpage. so you will get a little better flow.
Old 01-14-2004, 12:49 PM   #9
mrpute
You're right. My bad
Old 01-14-2004, 12:59 PM   #10
Silentalero
Kitteh is back!!!!
Silentalero's Avatar
well guys this summer (if time and money lets me) Im going to be doing a full stage 3 turbo setup from exploitracing, and since he's in WI im going up there personally.
Ill have dyno's n whatnot because ive decided to keep the 2.4L and work with it. So after i get it tuned n whatnot ill give ya guys some stats
97 Nissan 240sx - sr20det
94 Nissan 240sx convertible
01 Suzuki gsxr 750
Old 01-14-2004, 08:38 PM   #11
Final-Reality
Be sure to take lots of pics if you do it silent
Old 01-21-2004, 02:03 PM   #12
brad_galles16
Would it be best to get a turbo charger or to just buy a new v6 engine?? Thanks. How much hp would I get with the turbo charger??
Old 01-21-2004, 02:11 PM   #13
Silentalero
Kitteh is back!!!!
turbo is dyno'd at 190hp and alot cheaper than a v6 swap.
01 Suzuki gsxr 750
Old 01-21-2004, 10:03 PM   #14
j{}n
j{}n's Avatar
wait, that's not an additional 190hp, is it? or is that including the stock 150hp?
gee marc, you get that, and you might be able to pull all of your weight fast enough to compete with a stocker :rolleyes:
'05 mazda 3
zoom zoom biatch
Old 01-21-2004, 11:17 PM   #15
Silentalero
Kitteh is back!!!!
/\ htats what im thinking, lol
01 Suzuki gsxr 750
Old 01-22-2004, 02:31 AM   #16
Fast Eddie
IMO that is hella weak, esp for a stage 3 setup. Only like 35 HP over stock
I'm on a boat.....
Old 01-22-2004, 09:00 AM   #17
`2000redalero
Anyone wanna just give me like $2000 ? :P
Old 01-22-2004, 02:04 PM   #18
kwicslvr
Originally posted by Fast Eddie+Jan 22 2004, 02:31 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Fast Eddie @ Jan 22 2004, 02:31 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Silentalero@Jan 21 2004, 01:11 PM
IMO that is hella weak, esp for a stage 3 setup. Only like 35 HP over stock [/b][/quote]
The question should be is if that is 190whp. If so that would be a huge increase in power. Even if it isn't it is a 40 hp gain which isn't bad for a car starting at 150hp. Almost a 30% increase.
Old 01-22-2004, 06:56 PM   #19
Final-Reality
The problem is the pistons and rods in the 2.4 are relatively weak, so you can't turn up the boost too high without replacing those parts because they will break. 10psi is probably the max you should go if you want a stock 2.4 to last any length of time.
If you port & polish your head and/or add more aggressive cams, and/or add a less restrictive exhaust system and/or intake, then you can increase the horsepower significantly without spending as much as you would tearing down the engine and replacing the pistons/rods and bearings, since all those things help increase airflow. And when you upgrading those items (head, cams, intake & exhaust) when the engine is under boost, the increase in power is more dramatic than if your engine were naturally aspirated...
Old 01-22-2004, 10:13 PM   #20
Oldsman
Owner
Oldsman's Avatar
stage 3 kit would be 190 whp. but that would be with an intercooler. there are guys running 6lbs dynoing at 190 whp.
but yea, 10 psi would be max on stock internals.
