04-23-2005, 10:49 AM
I purchased a set of 1.75" lowering springs for my 2002 Alero a year ago and they are great. However after I had them installed they made squeaking/knocking noises when driving around. I tried putting silicone spray on the strut boots but it really did not help. I was wondering if the stock strut boots are rubbing on the spring now that the suspension travel has been altered. What do I need to do as fix this? Has anyone else had this problem? Do I need to buy new struts with a smaller circumference dust boot? Dow I need to get new struts that are made for the lowering springs? Help!!
Weber
Daily Driver http://www.cardomain.com/memberpage/537877 Modifications: window tint, front and rear strut tower braces, Sprint lowering springs, Magnaflow muffler, SLP air temperature module, mesh grill, Sylvania Silverstar bulbs, Street Glow bulbs, MAP Enineering exhaust heat shield,Doctor Speed Stage 2 short ram intake, and a K&N cone filter.
Project http://www.cardomain.com/memberpage/518009
04-24-2005, 01:25 PM
The thing that you need to worry about is when you install the springs.. there is a rubber piece that go's on the bottem of the strut between the strut and spring, if thats gone it can make some noise... besides that make sure that all of your hardware is TIGHT, the noise is prolly one of those things
04-24-2005, 10:03 PM
I don't think the struts are set right. I will have to take pics and post them or something. I plan on taking it to a shop, maybe they will know whats up.
Weber
04-25-2005, 12:08 AM
AutoCross Alero
mine adjusted for aprox a month after install, but i installed them myself, i loosened all the top strut bolts turned the front tires from stop to stop twice and retorqued them never popped again.
i did that with the all the weight on the tires on the ground.
04-25-2005, 12:42 AM
hmm yeah my driver side front strut makes a creaky noice, on bumps, and on occasions will pop on a large turn, i'll try what you did jab
AUTOBOT
