Old 04-26-2005, 08:01 PM   #1
PimpinGad
What is the widest wheel you can put on an alero. My friend has some Limited Type 341 on his 2001 Mitsubishi Galant, and I was just wondering if they would work on mine. I'm getting and 18 in. rim but they only sell 7.5 or 8.5 and he has no idea what it is would either work or what. I don't want to take it to a tire store to see if it will work because I'm spending all my money on the rims, so I don't want to pay them to tell me it will work or anything. But I need all the help I can get
Old 04-26-2005, 08:39 PM   #2
|Rev|
the 7.5 would eaisly work, 8.5 you might have probs depending on if you have lowering springs, and what size tire you put on, but an 18x7.5 rim will fit fine, thats waht my new rims are and I have the sprint lowering springs
Old 04-27-2005, 10:24 AM   #3
Oldsman
Owner
Oldsman's Avatar
i would 8 inch rims would be widest. depending on tire height and tire width you might be able to fit a 8.5 but would need to space it out to give a safe enough clearance from the strut.
Beware of the BackStabber
Old 04-27-2005, 12:18 PM   #4
PimpinGad
I'm going to just go to his house and see what the diameter is with the tire and the width. If all else fails I'll use a tape measure
Old 04-27-2005, 12:30 PM   #5
Oldsman
Owner
Oldsman's Avatar
depending on offset and tire width the 8's might rub. best bet is try them on and see
Old 04-27-2005, 01:14 PM   #6
PimpinGad
Is there anything in specific I should look for or just make sure I can fully turn the wheel and that it doesn't rub the springs
Old 04-27-2005, 01:53 PM   #7
Oldsman
Owner
Oldsman's Avatar
that is basically it. make sure there is enough room for give in the suspension.
Old 04-27-2005, 04:23 PM   #8
ktjhbh
I have 18 x 8.5 rims with 225/40/18 rubber and they fit fine with no clearance issues. I also have eibach lowing springs also.
Old 04-27-2005, 04:56 PM   #9
jabartram
AutoCross Alero
jabartram's Avatar
i'm running 235/40/17's and i can barely get my pinky between my back tire and strut.
Old 04-27-2005, 06:05 PM   #10
Naich
The Founder
Naich's Avatar
it all depends on the offset.... I'm running +40 offset and 235/50/17 and there is like 3 mm of space between the tire and strut.
Old 04-27-2005, 06:43 PM   #11
PimpinGad
Off set of the tire on the rim????
Old 04-27-2005, 07:43 PM   #12
No offset is the inside of the wheel going around the brakes
must be between +38 to +42. I tryed +45's and the wheels where rubbing the calipers and the wheels would wobble
Old 04-27-2005, 11:08 PM   #13
mfuller
CLICK HERE FOR AN EXPLANATION OF OFFSET
