Old 04-28-2005, 10:17 PM   #1
Dethwalkin
Have any of you guys had the problem of the abs and traction control turning off by it self? When this happens, the service light comes on too. I have just had my rotors machined for the second time and the problem went away for a week or so. Now almost evey time I drive the car those lights will come one and those functions will turn off. Man I'm so sick of the problems with this car, I could puke. 40k and I have had my catalitic converter die, windows fall off the tracks, rotors machined twice, keyless entry remote die, I even had to return a 4000 dallor dvd 5.1 suround system because the car kept turning it off. :rolleyes:
Old 04-28-2005, 10:24 PM   #2
Molson
Molson's Avatar
hit the search button. pretty common. you have a hub assembly on the way out.
Old 04-28-2005, 11:48 PM   #3
SlickSketcher
SlickSketcher is an unknown quantity at this point
Send a message via AIM to SlickSketcher Send a message via MSN to SlickSketcher
same thing happened to me. it's the speed sensor in one of your front hubs. the entire hub will need to be replaced.
2004 GL2 3.4L V6
SlickSketcher is offline   Reply With Quote
Old 04-29-2005, 08:12 AM   #4
theericharris
How hard is it to replace this hub? My GF's alero is doing the exact same thing.... very annoying. Is an indy shop going to rape me for the labor/parts for this? Is it an easy DIY project??
Any tips or pointers on what's involved would be great
Old 04-29-2005, 06:48 PM   #5
SlickSketcher
my friend and i did it....but we had access to a full lift. should be no problem up on jack stands and such. just set aside a few hours and be carefull with them.
2004 GL2 3.4L V6
Old 04-29-2005, 06:52 PM   #6
SlickSketcher
a dealer will rip you off pretty bad. try to do it yourself. you'll need to have a code read-out to figure out which hub you need to have replaced. and then don't forget to clear the codes so it doesn't get confused and think the new one is bad too.
2004 GL2 3.4L V6
Old 04-29-2005, 07:51 PM   #7
theericharris
She took it to AutoZone and they said there were no codes registered.
Any ideas what this could mean?
Old 04-29-2005, 08:02 PM   #8
coolero
I had to tak it to the dealership for scan
