Old 05-01-2005, 10:23 PM   #1
psu2ski32
I figured I would try a new post and see if I got any response. I was cleaning my car the other day and noticed that my rear power window switch ( black switch) had been knocked out of place. It is very loose and i am almost able to turn in a full circle. I believe that these little black plastic switches just snap on to the metal switch the is in the actual panel. Is there any way to get the little black plastic switch in place. Any Help would be appreciated.
Old 05-01-2005, 10:36 PM   #2
Caffineboy
you may have to take the panel off and look to see...never happened to me tho. sorry
Old 05-01-2005, 10:40 PM   #3
psu2ski32
How would i go about taking the panel off, i am fairly new at this. Thanks for your response
Old 05-02-2005, 12:33 AM   #4
if it's the one i'm thinking it is ... on the underside of the door "handle" (right under the switch) there should be a plastice piece... pop that off and it should reveal some screws... that should get you that much closer to getting it apart... once you get the panel out of the housing you should be able to see what you need...
