Old 05-02-2005, 09:40 PM   #1
-Alero-
-Alero-'s Avatar
apparently they have 160 degree thermostats for our cars at summit racing. here is the part number HYP-1005
but what i was wondering was, is this too low?
AUTOBOT
Old 05-02-2005, 10:31 PM   #2
160 is bad for the motors according to reports, engine temps can still spike frequently to about 220 or more, then dropping to 160 again. This happening repeatedly can cause mild or worse warpage in the cylinders and heads.
Best bet is probably a 180 with an upper end coolant like DEX-COOL (from GM dealer) or Texaco-Havalene from autoparts store, both of which are Ethylene Glycol based as opposed to Propylene Glycol. Eth. Glycol has higher heat tranfer ability, as well as higher quality additives for corrosion inhibiters than Prop. Glycol
*edited*
Here is what I was reading, from 60degreev6.com
http://60degreev6.com/modules.php?op=modlo...artid=16&page=1
Further, here is a previous discussion on the topic within this board, but I think the related articles had more to do with a 3800, but I'm sure the same principles apply:
http://invision.aleromod.com/index.p...ic=6372&hl=160
Old 05-03-2005, 05:09 PM   #3
-Alero-
-Alero-'s Avatar
well thank you, hats off to you, that was very good ino and i am not gonna get the 160
AUTOBOT
Old 05-03-2005, 07:22 PM   #4
glad to help if I'm able to. BTW, if you wouldnt mind, can I get a bigger pic of your icon (motor)? that looks pretty trick
Old 05-03-2005, 08:42 PM   #5
-Alero-
-Alero-'s Avatar
lol why sure!
AUTOBOT
Old 05-03-2005, 08:52 PM   #6
-Alero-
-Alero-'s Avatar
lol here it is!
notice the fine detail
AUTOBOT
Old 05-07-2005, 04:00 PM   #7
jiffy
what are the benefits/drawbacks of changing your thermostat temp?
Also, what is our stock one?
Old 05-08-2005, 12:46 PM   #8
bigd6983
stock is 195 and the benefits of it are instead of your thermostat opening at 195 degrees it will open at 180 degrees, which will rotate the fluids more often keeping the engine a tad cooler.......
Old 05-08-2005, 12:56 PM   #9
....which in turn keeps your fuel/air more dense, in turn making a tad more horsepower
Old 05-08-2005, 06:50 PM   #10
jiffy
thanks.
Old 05-09-2005, 12:36 AM   #11
bigd6983
lol good follow up black jack......
