Old 05-03-2005, 09:14 PM   #1
FutureEcotecOwnerAgain
well i'm sure you know i got the ecotec and i have a 2.5 inch cat back exhaust with header, and intake. and i also have an automatic. the reason i'm asking is because i've just been doing some research on certain cars and their 1/4 mile times and i was just trying to compare. any info is helpful. keep in mind i live in tennessee. about 45 miles northwest of nashville in clarksville.
Old 05-03-2005, 11:07 PM   #2
You'll probably run mid 15's
Old 05-03-2005, 11:27 PM   #3
mid 15's would make me happy compared to what i would run stock.
Old 05-04-2005, 09:04 AM   #4
Leave it in "3" go on the 3rd amber
Stall lanuch at 2000 RPM's and if you spin or even chirp you tires, you hurt your time.
Go around the waterbox, and deflat front tires to about 26 psi or so, do a little bit of a burnout before pulling up to the line.
Set yourself up in the tire tracks of the car that left before you, called "running the grooves"
(Everything I learn, I learned from Daytona) :hide:
