Difficulty:
TIME:
HOW TO: Install white gauges
Special thanks goes out to Molson: first for selling me his drjracing white gauges and secondly for providing me the initial instructions on how to install them. :thumbsup:
Tools required: Pencil, Paper, Ratchet Tool set
Begin: Record where your needles are set, especially the gas needle. Use the Pencil and paper for this.
1. Begin by removing the two screws at the top of the gauge trim.
2. The bottom section is clipped on, so tug on it to pull it out.
3. Unclip the trip button. Pull the trim out until you can see and access the trip button connection on the inside. There is a small clip normally located on the bottom of the connection.
4. Remove the trim.
5. There are four screws holding the cluster. Unscrew these, careful to not drop any screws inside the dash, they are a pain to retrieve.
6. Remove the cluster but notice the wiring connection attached at the top of the cluster. Unclip this connection to completely remove the cluster.
NOTE: Recommended you work in a more comfortable area now.
If you are changing the cluster bulbs, proceed to step 17
7. Unclip the front cover, exposing the gauges and needles.
8. Remove the pins (the ones that hold the speedometer and RPM needles at 0).
9. Remove the needles. It was suggested to me that using a fork works beautifully, and it did.
10. Begin removing the stock gauge cover. This is extremely sticky so be careful. Once completely removed, place in an area where nothing can or will stick to the gauges.
11. Place your white gauge cover.
12. Place the pins and the needles.
13. Plug wire connection back into the cluster to test if needles are set correctly. If you place the cluster back in the dash, be careful when/if adjusting the needles as they may fall in dash. Recommendended you test with cluster on steering column.
14. Once adjusted, clip front cover back on. Place cluster back inside dash (if not done already).
NOTE: cluster should be plugged in at this point.
15. Rescrew the cluster in place.
16. Take trim and reclip the trip button, the place the trim back in place. Make sure the bottom clips into place and the top screws are in place as well.
Done installing white gauges.
Changing cluster bulbs, continue from step 6
Bulb model numbers:
- 194 (5 bulbs)
- 24 (4 bulbs)
17. Unclip the rear cover, exposing the circuit board.
18. Turn the grey knobs roughly half a turn counter-clockwise to remove the bulbs.
19. Replace bulbs.
20. Re-clip rear cover. Plug in cluster and place into original position.
21. Please see step 16.
Done changing bulbs
Note: If you needles have adjusted incorrectly, you will have to reset them. Can't drive around with improper RPM, Speed, Temp and Gas ratings can we?
