so i cleared my corners several weeks ago and now that spring has arrived i have noticed a small amount of moisture building over the blinker area. It is just a small film that covers about the bottom 1/4 of the blinker area so im not going to rip the silicon apart. just wandering if heating it might get rid of enough of it to make it unnoticable?
try taking the headlight out and take the rubber covers off and hold a hair dryer in there on low for a couple of minutes. then put some more silicon on it just incase theres a leak or something.
you can stick it in the refridgerator or use a dryer either way should get the moisture out. same principle with clearing moisture from your windshield you can use the ac or heat...
