Old 06-13-2005, 09:18 PM   #1
RedAlero02
I'm installing my amp and I've got a couple questions with the remote wire.
I have the radio harness from pioneer if that helps too.
Where do I put the remote wire in???
Any tips.
I can answer more questions if needed.
Thanks
Old 06-13-2005, 09:31 PM   #2
mikegett
mikegett's Avatar
I am not sure of what you are asking. Do you want to know where the remote goes to the amp or what wire to use from the HU to the amp? Your HU should have a blue or possibly blue white wire called remote or amp line. You run that back to the remote turn on for the amp. It will be located between the 12 volt positive and 12 volt negative. If you don't see a remote turn on located on the amp, it may be a sensing type. Meaning your amp senses the voltage on your rca and turns on. In this case ignore the remote wire.
Old 06-13-2005, 09:33 PM   #3
RedAlero02
Sorry. My bad.
Yes... i can't find out where to put the blue remote turn on/off wire on my pioneer head unit.
Any ideas on where it goes
Old 06-13-2005, 09:36 PM   #4
mikegett
mikegett's Avatar
List the wires on your pioneer harness if you don't see one stating amp or remote wire. At the very least, you can run the switched 12 volt off of your HU back to the amp. The only issue here is that if your amp doesn't have a soft turn on you will get a popping. What amp do you have?
Old 06-13-2005, 09:39 PM   #5
RedAlero02
My amp is a kenwood:
http://www.bestbuy.com/site/olspage.jsp?sk...d=1099388637212
My HU is a Pioneer deh p3600
Old 06-13-2005, 09:42 PM   #6
RedAlero02
I looked at the wires...
One is labled "amp turn on"
I'm guessing thats what I need?
Old 06-13-2005, 09:52 PM   #7
mikegett
mikegett's Avatar
I just looked at the pdf file. If is the blue and white wire labled amp turn on.
Old 06-13-2005, 09:57 PM   #8
RedAlero02
Yeah. Thats it.
Thanks.
I think I know what to with the rest now.
Old 06-13-2005, 10:05 PM   #9
Vtolds
H&B Shipping Agent
Vtolds's Avatar
its always a blue wire, or blue with a white stripe. It will always say Amp Turn On or Remont Antenna.
Old 06-13-2005, 11:08 PM   #10
RedAlero02
OK. One slight problem.
I hooked everything up again... but my radio signal seems to be crappy.
Could any of the new things I've done added interference to the radio signal?
Old 06-14-2005, 12:20 AM   #11
RedAlero02
OK. I think I figured this one out too.
I didn't hook my remote wire to my amp up... so the power antenna wouldn't power up either.
It's either that... or when I moved the wires around a loose connection fixed the problem.
Was that the problem... the wire not hooked up to the amp??? Just wondering, because if its not I have to figure out what went wrong so it doesn't happen again.
Old 06-14-2005, 10:52 AM   #12
RedAlero02
OK. This remote wire.
Do we splice our remote wire into the amp turn on... or do we cut the original amp turn on and put the new wire I got in my kit to the radio harness.
I did it the second way... and thats when I noticed the radio signal started to get crappy.
Old 06-14-2005, 11:29 AM   #13
knowfear
you should have a wire on the headunit and a wire in the car both specifically for the use of the power antenna. if you forget to hook it up, you will be hard pressed to find a station that will come in very good at all. i didnt hook mine up at first and then afterwards i connected it and i havent heard any static since. the station i listen to most is about 65 miles away from me.
Old 06-15-2005, 12:43 AM   #14
mikegett
mikegett's Avatar
The antenna booster can be a pain depending on the car. Some years have a green wire for the radio and others have blue one. This is the collor of the wire on your factory harness. Try splicing the new HU antenna into one or the other until you get it. You will notice a big improvement.
The "remote turn on" wire is the same thing as a amp turn on. These are the two you will want to splice togeather for your amp. Avoid using the power antenna. Most aftermarket HU's will only supply power to this lead when the fm or am station is selected. In that case, your amp will not power up in cd mode.
Old 06-15-2005, 01:10 AM   #15
AleroBloke
opc1:
Old 06-15-2005, 04:37 PM   #16
alero_ecotec
Special Agent
alero_ecotec's Avatar
alero_ecotec is an unknown quantity at this point
maybe that's my problem, b/c i get crappy radio reception too. I'm not really sure what goes to what though. I know i have my power wire run to the fuse box on the drivers side....and my aftermarket amp turn-on also gets its juice through the power wire because it doesnt work with the amp turn-on wire ..........i dont know, i really dont want to take my crap apart to figure out the antenna but i guess i could.....if anyone knows what's supposed to be hooked to what let me know
THE Ohio State University!
alero_ecotec is offline   Reply With Quote
Old 06-15-2005, 06:31 PM   #17
RedAlero02
Thank you.
You've answered two questions in one post.
I'm going to start finishing everything tonight.
I'll let you know how it goes.
Thanks again for the help.
Old 06-15-2005, 08:45 PM   #18
RedAlero02
I now have my full signal back and the remote wire working when the cd plays as well.
Thanks again.
