Old 06-17-2005, 02:47 PM   #1
VCguy85
VCguy85's Avatar
VCguy85 is an unknown quantity at this point
Send a message via AIM to VCguy85
Ok so I finally got pulled over for my tint. That, and my license plate cover. I don't want to pay anyone to take it off the tint, so what solution should i use to get the stickys off after i rip it off myself??
VCguy85 is offline   Reply With Quote
Old 06-17-2005, 02:50 PM   #2
Pimpalero03
peel it off, then spray the window with windex or whatever and use a flat razor and go up and down to scrap off the glue
Old 06-17-2005, 02:51 PM   #3
MCKALERO03
MCKALERO03's Avatar
MCKALERO03 is an unknown quantity at this point
Goo Gone works pretty good...
http://www.royalpontiac.org
MCKALERO03 is offline   Reply With Quote
Old 06-17-2005, 02:58 PM   #4
at any decal shop or graphic shop where they do vinyl decals they have stuff called "rapid remove" well... usually they have that ... the place i worked had it... and it works brilliantly for pretty much anything that's stuck on windows or whatever else you wanna take it off
Old 06-17-2005, 03:02 PM   #5
99BLKALERO
samething happend to me when I had my alero...i used pimps method...but it was a pain..and i ended up with a few scratches on my windows...
Old 06-17-2005, 03:42 PM   #6
johny_boy32
johny_boy32's Avatar
goo gone and a razor blade with work fine.
Old 06-17-2005, 04:39 PM   #7
I just peeled mine off a couple weeks ago....just use a sharp razor blade to start peeling it from the window. After you get it started, you really don't need the razor, just go slow. When you're all done, just use some glass cleaner and another sharp razor to go over the window. Took me 2 razors and 15 minutes to complete...
Old 06-17-2005, 04:54 PM   #8
SprtSedan01
SprtSedan01 is an unknown quantity at this point
Send a message via AIM to SprtSedan01
I had the same exact situation recently, my tint and license plate cover. Just use a razor blade to peel back the edge, and then you can pull it off by hand. To get any residue off, go to Wal-Mart auto section and they have "Tint Off". Works great, you'll use a lot of it to get everything off though so you may want 2 bottles of it. Also, as you are peeling back the tint, continuously spray the "Tint Off" between the tint and window to help seperate, this will leave less residue afterwards. Hope this helps, good luck.
Will Warren
*USAF*
*00 Passat 1.8T*
*00 Alero 3.4*
*01 Alero 2.4*
*10 Expedition*
SprtSedan01 is offline   Reply With Quote
Old 06-17-2005, 08:15 PM   #9
VCguy85
VCguy85's Avatar
thanks peeps!
Old 06-17-2005, 08:22 PM   #10
cutelilcntrygrl
I love boobs
cutelilcntrygrl's Avatar
cutelilcntrygrl is an unknown quantity at this point
Another helpful tip, when you're peeling it off, spray some windex on the window as you're peeling it off. Like, get a good start on peeling it and spray as you peel, in the crease. This method gets the whole peice of tint off at one time rather than little strips at one time. It worked on my Talon. Hope you get what I'm saying.. kinda hard to explain without showing you.
http://www.myspace.com/smr612
cutelilcntrygrl is offline   Reply With Quote
Old 06-19-2005, 09:34 PM   #11
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
^ not only does that help getting it done in one piece, you're also preventing the sticky goo from staying on your window.
Old 06-19-2005, 11:39 PM   #12
TwistedDreams
VIP
TwistedDreams's Avatar
TwistedDreams is an unknown quantity at this point
Send a message via AIM to TwistedDreams
cutelilcntrygrl I also had a Talon before I got the Alero it was a 94 Green Eagle Talon DL
What did you have?
Gunnery Sergeant Hartman: "I'm going to rip your balls off, so you cannot contaminate the rest of the world."
TwistedDreams is offline   Reply With Quote
Old 06-19-2005, 11:50 PM   #13
cutelilcntrygrl
I love boobs
Mine was 95 TSi AWD
