Old 07-09-2005, 07:19 PM   #1
-Alero-
-Alero-'s Avatar
ok my SES light came on so i went and got it scanned, and here are the results.
P0301
Cylinder 1
misfire detected
P0336
crankshaft position
sensor A
CKT range/perf
ok i can take the plug out and look at it, and possibly change the wires, but im not sure if that will help.
and i changed my crank pulley to the FFP pulley, and im guessing there is a problem there, so i will have to take it apart again to look at it.
any insight is appreciated :tumbleweed:
AUTOBOT
Old 07-09-2005, 09:42 PM   #2
FormulaNERD
looks like you need the dealer to do a case relearn
Old 07-09-2005, 11:56 PM   #3
-Alero-
-Alero-'s Avatar
why a relearn? i dont have the PCM maxed out.
so a crankcase relearn would fix this?
AUTOBOT
Old 07-10-2005, 06:38 AM   #4
^yes
and change out the plugs
Old 07-10-2005, 07:55 AM   #5
-Alero-
-Alero-'s Avatar
i just changed my plugs 10k ago........
and its hell taking this plug out! im still working on it! its f***ing rediculas!
AUTOBOT
Old 07-10-2005, 10:11 AM   #6
-Alero-
-Alero-'s Avatar
Originally posted by Redog@Jul 10 2005, 06:38 AM
^yes
did this happen to you when you chanegd your crank pulley?
AUTOBOT
