07-28-2005, 04:19 PM
I have my setup ready to go, but with some of the other things i am adding into the trunk, i would like to secure the sub box so it dont move around in my trunk, as i will also be placing the motherboard and all the hardware for my carputer in the trunk, so anyone have any ideas for how i could mount the subbox down in my trunk? thanks for the help
07-28-2005, 04:21 PM
L-brackets or some industrial grade velcro.
07-28-2005, 04:27 PM
do what i did...screw bolts down through the bottom...making sure u wont hit anything...and use some sort of sealant on the bottom for water...just for extra water protection...works for me and they DO NOT move lol
07-28-2005, 05:25 PM
thats why i was iffy to screw bolts down through the trunk, cause i dont have access to really get under there to see where the gas tank is and all
07-29-2005, 03:09 AM
Special Agent
hmmm, mine's not secured, it just weights about a thousand pounds, it's never moved
THE Ohio State University!
07-29-2005, 12:12 PM
I'd use several L-brackets.
07-29-2005, 12:13 PM
H&B Shipping Agent
My box doesnt move, but it wieghts like 100 pounds.
07-29-2005, 03:32 PM
Mine weights about 120lbs and would normally slide a bit. so i used some L brackets. Everyone says "watch out for the gas tank!" but w/ it all the way up in the trunk, its still about a foot from the tank.
Hope these help.
[attachmentid=8000]
[attachmentid=8001]
The braces hold it good and tight.
07-29-2005, 08:18 PM
H&B Shipping Agent
Yeah the gas tank is actually under the back seat.
07-30-2005, 02:37 AM
i used velcro like a long strip on either side and it works beautifully
07-30-2005, 01:10 PM
I bolted mine in from the seat side with a shed door latch, so one piece is on the frame and one on the box, and I used quick disconnect connectors on the wires.
Nothing worse then having a flat in the middle of nowhere and not having a screwdriver to remove the box with! Plus, if you drag race, makes removing it a snap.
-Aaron
'04 Alero GL1 - 2.2 DOHC A4
'00 Intrigue GLS - 3.5 DOHC A4
07-31-2005, 05:50 AM
just put a couple 10 inch strips of velco on the bottom of the box, and use a staple gun to staple it into the box, works like a dream
 2006 Toyota X-Runner
08-01-2005, 11:18 PM
where is the tank at? i used the same thing but mine is in the back near the mounting of the back seat. and i used 1 and 1/2 in screws.
