I'm a bit fuzzy on this step for replacing brake pads. I was reading the
GM service manual and the
Haynes manual for my Alero on how to change the front brake pads. Now both sources say to empty 2/3 of the brake fluid out of the reservoir. I talked to some people at part stores and mechanics and they think that is a weird thing to do. They say to just use a large C-clamp and compress the piston as is. One mechanic said to pump the brake pedal 20 times with vehical off and then compress the piston.
What is the proper, yet easy, way to replace brake pads on the Alero??
