I went LED front turn and rear turn signals which required (1) 3 ohm resistor on each side of the car. This would be your best bet because one on each side of the car takes care of everything. 194 bulbs dont require any load resistors so no need to worry about that. I got them and my bulbs from here
CLICKY
If you havent already bought the bulbs, get the ones with some side firing LEDS so you can make use of the reflectors in the housings
