Old 08-16-2005, 05:40 PM   #1
terrylink
terrylink is an unknown quantity at this point
Angry
I have to find new brackets for the back of my headlights. They are the pieces that fit through the header(mounting) panel. I am coming up empty on this. Anyone know how I can get some of these......Help please. Thanks
terrylink is offline   Reply With Quote
Old 08-17-2005, 05:59 PM   #2
eag182
header panel?
Old 08-17-2005, 06:01 PM   #3
uhm those little tab things you push up and down to remove/secure them??
Just call the dealer, you can get pretty much anything under the rainbow from them, for a price.
Old 08-17-2005, 08:34 PM   #4
terrylink
The tab things you refer to are a part of the header/mounting panel. What I am after is actually phillips screwed onto the back of each headlight. There are two per headlight.
Old 08-17-2005, 08:53 PM   #5
terrylink
The black plastic panel that is directly behind the headlights. The headlights are secured to this panel. This panel has the clips that slide up and down to secure the headlight. Anyway i am looking for the plastic pieces that screw onto the back of the headlight and in turn fit through the "panel" and then secured. Hope this helps, thanks.
