Old 08-17-2005, 02:14 PM   #1
zsmith
I was lookin to get a 62mm rsm racing throttle body has anyone got one yet? Are the worth 200 dollers. I want as much power as i can get for cheap with out going with any boost. any suggestions?
Old 08-17-2005, 11:20 PM   #2
Oldsman
Owner
Oldsman's Avatar
not worth the $200 on a N/A motor.
save your money and get a 2.3 HO TB which is a 56mm. it's a much bettter choice and normally can get one from ebay or junkyard for under $75.
Beware of the BackStabber
Old 08-18-2005, 08:24 AM   #3
zsmith
how would a smaller TB be better? It says 10 hp is that a lie or what?
Old 08-19-2005, 07:28 AM   #4
Final-Reality
Yes it's a lie, 62MM is too big for a naturally aspirated engine. It stifles air velocity (or air flow). Think of it like this: Your current throttle body is a 6" diameter water pipe that has to carry 500 gallons per hour of water. There's going to be a lot of pressure in that pipe and it's too small to efficiently carry that much water. A 62mm throttle body is like a 10-foot diameter pipe carrying 500gph of water. It's so damn big that the water is barely going to be moving, it's just a little stream at the bottom of the pipe and the water is barely flowing, this is bad as well. A ~56mm throttle body is just the right size; it's large enough that the water can efficiently move through the pipe, but not so large that the water doesnt have to flow at all. Get it?
Old 08-19-2005, 08:01 AM   #5
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
^ I get it.
62mm = like throwing a pencil down a chimney
56mm = nice and tight, empahsis on NICE
Old 08-19-2005, 10:22 PM   #6
Oldsman
Owner
Oldsman's Avatar
i have the 62mm and you lose bottom end with it. you do gain in the high end. like 5000-6000 rpm.
with normal mods it is not worth the bottom end lost.
but it is good for boost.
Old 08-23-2005, 02:18 PM   #7
UnoWHO
I changed the tb to the 56mm and shes a dream :-D
Old 08-24-2005, 05:08 PM   #8
Final-Reality
Did you just take a 56MM TB right off a 2.3 QUAD4 engine and throw it on your 2.4? I'm curious to know how much work is involved if you just transfer it directly from one stock engine to another, IIRC there's some issues involved with the throttle cable bracket.
Old 08-24-2005, 11:18 PM   #9
UnoWHO
Nah mines the stock tb but its bored to 56mm
Old 08-25-2005, 02:27 PM   #10
zsmith
I just purchased a 56mm tb of the internet for 215dollers after the 50doller core charge hopefully it worth the money.
the website was theraceshop.com or something like that, its for the 2.4 cavalier just for everyone else to know.
Old 08-25-2005, 03:14 PM   #11
ptrudel
Designated Drunk
thats fairly expensive if you ask me...woulda been better off gettin Schimmel's intake mani and tb for 125$...should be a good mod either way tho
I'm baaaackk
Old 08-28-2005, 05:57 PM   #12
Spy
theraceshop good guy runs that place.... Think mantapart, but actually having product in stock and great customer service.
