01-25-2004, 10:27 PM
take this bolt out and the one on the other side as well........
01-25-2004, 10:28 PM
then these bolts, they're kinda hard to get to because of the seats........
01-25-2004, 10:29 PM
in the center console, there is a small rubber mat in the bottom, remove it and you will see two bolts, take them out...........
01-25-2004, 10:30 PM
here's the pic........
01-25-2004, 10:33 PM
when all of the olts are removed, you will need to make sure that the keys are in the on position. *make sure the car is turned off* drop the gear down to 1st or 2nd gear and then pull the section around your shift knob up......it should just snap out........
01-25-2004, 10:35 PM
with this done, pull out on the sides of the console, it should snap out.........pull out on these corners.........
01-25-2004, 10:38 PM
pull up on the back of the console, and pul back on the whole thing at the same time........when you get it out turn it over.........you'll see the screws that hold the top and the bottom of the console together........remove only the outside screws.......i've got them maked on one side, but you can't see the ones on the other side in the picture............
01-25-2004, 10:39 PM
here are some more.........
01-25-2004, 10:41 PM
make sure you get these two as well.........they are hidden above the cup holders in the back..............
01-25-2004, 10:43 PM
once all of these screws are out, the top part will lift off of the bottom part..........next, you will need to remove the screws holding in the boot........
01-25-2004, 10:49 PM
after they are removed.........you can pull the plastic retainer and the boot will be stapled to it........remove the staples and pull the boot off of it..........place you new boot in the same way the old one was there.........you will have to replce the plastic retainer with the boot on it, and then put the screws through the boot to hold it in, unless you have a heavy duty stapler............after this is done, just reassemble the top and bottom parts opposite of how you took them apart. the rest is pretty much self-explanitory............these are the best pictures i have, if anyone has any questions, you can esnd me an im...........have fun!!!!
02-24-2004, 11:25 PM
Thanks that will help but what about auto shifter boot? I have one for itHow would I go about putting that on? :unsure:
02-24-2004, 11:58 PM
I have a 2002 and i did not have to remove all the screws, only the ones holding the boot on.
2002 GL2 4DR, MYMODS:In dash 7" VGA Widescreen monitor, XM Satalite Radio, Clarion Amp, 2 10" Audiobanhn DVC Subs Hidden HitchTrailer Hitch, Grill Mesh
02-25-2004, 01:31 PM
Im not sure if you looked carefully dude - those instructions were for the A/T console...
Hey Alerospeed2003, as far as your pic collection dude, do you have any pics of the ebarke handle without the boot on? From what you saw, was it possible to change the E-Brake handle as well??? Good work, I just noticed I have a big rip in my boot, so im gonna find a red one to change it with. Good How-to dude, keep up the good work! :thumbsup:
02-25-2004, 07:19 PM
^^^I did read it, but did you read mine?
I said that I got a boot for the A/T shifter and asked how to bolt it in.
I have a e brake boot to install too
03-10-2004, 10:45 PM
AUTOBOT
12-01-2006, 02:32 AM
Originally Posted by 99redcoupe
 how come i cant see the pics can you put the link in again? plzzz
x 11tybillion.
I'm actually looking for a picture of the exhaust hump, to compare it to another car for an idea I have.
