Old 09-06-2005, 10:52 PM   #1
gutlesschimp
So im buying a dual exhaust and i need to cut a slit in the back bumper, and i have no idea how to do it...What do i need?How do i do it?Should i wait until the exhaust is mounted on and just cutaround where it needs to be, or should i cut it first and then put the exhaust on...THANKS...
also if u say a tool i need could u gimme a link to a pic of it...im not a big handy man...thanks....sorrry if this was the wrong place to post this...
thanks.....
matt
Old 09-06-2005, 11:45 PM   #2
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
if you're having someone else install the exhaust, they will cut it for you.
Old 09-06-2005, 11:45 PM   #3
jabartram
AutoCross Alero
jabartram's Avatar
i made a template of the factory one with a sheet of paper, and masking tape, then measured the right side so i was sure to be in the same place reversed the template, taped it to the bumper marked the bumper with a marker, and cut it with tin-snips. came out great.
Old 09-07-2005, 12:23 AM   #4
Originally posted by jabartram+Sep 6 2005, 09:45 PM--><div class='quotetop'>QUOTE(jabartram @ Sep 6 2005, 09:45 PM)</div><div class='quotemain'>i made a template of the factory one with a sheet of paper, and masking tape, then measured the right side so i was sure to be in the same place reversed the template, taped it to the bumper marked the bumper with a marker, and cut it with tin-snips. came out great.
[/b]
ahem
<!--QuoteBegin-gutlesschimp
@Sep 6 2005, 08:52 PM
also if u say a tool i need could u gimme a link to a pic of it...im not a big handy man...thanks....matt
[/quote]
tin snips can be found at your local hardware store for $8 to $20.......
Old 09-07-2005, 12:26 AM   #5
gutlesschimp
that link didnt work...but i found what they are...thanks..yea im havin mineke install it so u think they will cut it?
Old 09-07-2005, 12:28 AM   #6
check now i just put the photo up......link wasn't working for me either......
and i'm not sure i don't go to chain places like that......
Old 09-07-2005, 08:58 AM   #7
ptrudel
Designated Drunk
tins snips?? my guy just took an air grinder to do it without a template and it turned out almost identical
I'm baaaackk
Old 09-07-2005, 09:58 AM   #8
AlbinoMonkeyRat
Let's Play Army!
pretty much any cutting tool will work with a steady hand. even a dremel. (but using a high-speed tool like a dremel, you'd melt the plastic and it would be smelly.)
Old 09-07-2005, 07:51 PM   #9
bluephoAm
I love the smell of burnt plastic in the mornin'...
Old 09-07-2005, 08:05 PM   #10
alero168
I Love Tiara!
alero168's Avatar
alero168 is an unknown quantity at this point
Send a message via AIM to alero168
what kind of exhaust did you get and how much and how much are they charging you for the install?
alero168 is offline   Reply With Quote
Old 09-07-2005, 11:34 PM   #11
bnight04
bnight04's Avatar
bnight04 is an unknown quantity at this point
Send a message via AIM to bnight04
I did the same thing, but didnt cut with tin snips. Dont have them do it unless you want to pay more.
2004 40th aniv. mustang
2006 kawasaki ninja
bnight04 is offline   Reply With Quote
