Old 09-19-2005, 03:54 PM   #1
thaoldsdr
Am I also the only one that has to fix my lighter and extra power outlet and wiring at least once a year. was there a recall on this problem.
Old 09-19-2005, 03:56 PM   #2
i've never had problems with mine...is your grounding wrong or what? wrong sized fuse in the box?
Old 09-19-2005, 09:38 PM   #3
eag182
stop smoking
Old 09-20-2005, 02:01 PM   #4
siether
siether is an unknown quantity at this point
My Ciglighter stopped working just last week, I used it like only 3 times and now it doesn't work. I even tried the aux. one, nothing. And I've checked all the fuses.
siether is offline   Reply With Quote
Old 09-20-2005, 02:47 PM   #5
Both are on the same fuse.
Could be a short
Old 09-22-2005, 03:11 AM   #6
thaoldsdr
Ive found its a common problem with aleros and I dont know why ill check for a recall on it.
Old 09-23-2005, 01:58 PM   #7
alerochick242
I've never had a problem with mine (I only used it once to light a firecracker, though ).
Old 09-23-2005, 02:05 PM   #8
pimpnalero99
I have a '99 and mine work like new. The only thing I had a prob with is the Aux one coming out of its spot. I think thats just b/c of the neons getting put in and taken out a lot.
Old 09-23-2005, 03:53 PM   #9
ImSoBored
ImSoBored is an unknown quantity at this point
Send a message via AIM to ImSoBored
never had a problem with mine. I gutted the aux. cig lighter and just kept the metal frame piece, the frame now holds a switch that fit perfectly in it.
ImSoBored is offline   Reply With Quote
