Old 10-18-2005, 11:39 PM   #1
ptrudel
Designated Drunk
alrite...175 000 kms(just over 109 000miles), and i'm gettin a noise that sounds like the valves ticking...possible?
also, its starting to lose coolant(very slowly, but still) and i'm losing oil pressure in sharp turns(over 25mph)
is my motor dead or what?
I'm baaaackk
Old 10-19-2005, 01:12 AM   #2
motor dead? im no expert or anything close but that would make sense.. these are pretty peppy lil engines but not too tough.. especially at over 100k miles
Mine was rebuilt at about 50k.. only cuz of the previous driver totalling it in some stupid way.
so i dunno =-P im sure someone on here has better info to offer you Patty cakes =)
Old 10-19-2005, 11:27 AM   #3
ptrudel
Designated Drunk
i've seen these 2.4's hit well over 120k miles with no issues...now, i drag raced and stuff like that, but i wouldn't expect it to die this quick...especially cuz i cant afford it right now ...
I'm baaaackk
Old 10-19-2005, 11:28 AM   #4
jamcllw
your screwed
j/k I know jack crap about the 2.4
Old 10-19-2005, 11:34 AM   #5
ptrudel
Designated Drunk
Originally posted by jamcllw@Oct 19 2005, 11:28 AM
your screwed
lol thanks for that expert outlook on things...even tho you say you know jack crap, you're probly right :Noooo:
I'm baaaackk
Old 10-19-2005, 12:42 PM   #6
DRA-GON
DRA-GON's Avatar
DRA-GON is an unknown quantity at this point
I honestly don't know what could cause the issue but I hope its nothing to serious/exspensive for you.
<img src=\'http://i11.photobucket.com/albums/a175/looper90/SIG.jpg\' border=\'0\' alt=\'user posted image\' />
DRA-GON is offline   Reply With Quote
Old 10-19-2005, 04:30 PM   #7
Fast Eddie
Without listening to the car its kinda hard to diagnose the problem. Are you sure its the top end and not the bearings? Does it get faster as RPMs increase?
Are you constantly replacing coolant or have you just recently noticed that the level is low?
How do you know you are getting low pressure in the corners? You could just be low on oil triggering the oil to move to the side of the pan and the idiot light to come on temporarily?
Change your oil and see what it looks like, metal in there is bad, very bad. Is there any coolant in there? If that is ok pull the plugs and see how they look.
I'm on a boat.....
Old 10-19-2005, 05:55 PM   #8
Oldsman
Owner
Oldsman's Avatar
valve ticking? i doubt it. maybe lifter noise. does it get louder or go away when you rev it up?
losing coolant since you have the miles you do i would say change you water pump.
losing oil pressure in sharp turns. well since our oil pan is not baffled this can me normal. it is a common problem with the 2.4. best bet is to change the oil and put 5 quarts in it the extra oil help from the sloshing. also it is not wise to take very sharp turns in the 2.4 because this leads to the #3 bearing going out which leads back to the sloshing.
i would recommend change oil, oil filter. add prolong to your oil. put in 5 quarts of oil.
also change water pump, t-stat, and coolant.
Beware of the BackStabber
Old 10-19-2005, 10:44 PM   #9
ptrudel
Designated Drunk
wow..thanks guys...as for the ticking, over 2500rpm it disappears..i think...i cant hear it, and haven't had a chance to put something other then burning my hand to see if its still there...
the oil level is up, i'll see what it looks like come oil change time saturday...
thanks again
I'm baaaackk
Old 10-19-2005, 10:51 PM   #10
kwicslvr
Well I have 139,000 on my 2.4 and it has never had an engine problem.
Old 10-20-2005, 11:12 AM   #11
j-work
Senior Member
j-work is an unknown quantity at this point
I have 84000 miles and I am just doing a tune-up before winter... new plugs, boots, and O2 sensor. Anybody recommend percautionary repairs or anything else while I have it taking apart?
j-work is offline   Reply With Quote
Old 10-20-2005, 12:06 PM   #12
Oldsman
Owner
Oldsman's Avatar
water pump and t-stat. and when you do that use a new timing chain and tensioner.
Old 10-20-2005, 12:08 PM   #13
Oldsman
Owner
Oldsman's Avatar
thanks again
another thing to check for ticking is the power steering fluid level. i noticed once mine was low and it made a odd noise. so check that out and top it off.
Old 10-20-2005, 06:43 PM   #14
keepitsimple
y amy engine died at 99000miles spun a bearing, thats why the rebuild, but kinda off topic i want to put a turbo on soon t3 and with my mods what do you think i can run for boost i was hopin at least 13 + and how much hp would i gain?
Old 10-20-2005, 11:03 PM   #15
kinda off topic? lmao
Old 10-21-2005, 10:32 AM   #16
Fast Eddie
Originally posted by Oldsman+Oct 19 2005, 03:55 PM--><div class='quotetop'>QUOTE(Oldsman @ Oct 19 2005, 03:55 PM)</div><div class='quotemain'><!--QuoteBegin-2000_olds_alero@Oct 18 2005, 09:39 PM
[/b][/quote]
If you put in too much oil you start to get froth from the crank whipping it up constantly and the pump will not pick it up. I'm not sure how much fill fit without frothing, but if the crank doesn't churn it, the balance shafts will, if you have them.
I'm on a boat.....
Old 10-21-2005, 07:55 PM   #17
Matthewfinlay04
I have 175K miles on mine and I just replaced the water pump, leaking from the weep hole. While in there we replaced the chain, guides, and tensionors. Also replaced the Thermo for the first time ever! Don't know about everyone else but other than regular maintance on my alero I haven't had any real trouble with it mechanically. As for the ticking I think that typical for the quad four engine to be a little ticky at idle. my had done that since we bought it with a little over 15K on the car. But if it gets louder as you rev then there def a problem. As for the leak check the water pump and all your hoses. Do you know approx the leak is comign from?? Passenger side prob the water pump. Driver side either upper raidiator hose or heater hoses, given that you don't have a blown gasket. As for the oil light?????
Old 10-22-2005, 05:09 PM   #18
Oldsman
Owner
Oldsman's Avatar
Originally posted by Fast Eddie+Oct 21 2005, 08:32 AM--><div class='quotetop'>QUOTE(Fast Eddie @ Oct 21 2005, 08:32 AM)</div><div class='quotemain'>
[/b][/quote]
by putting in the extra 1/4 of a quart there is no issues with the crank whipping the oil.
Old 10-24-2005, 02:42 PM   #19
Fast Eddie
.25 of a quart no, but you typed 5 quarts, cap is only 4.
I'm on a boat.....
Old 12-09-2005, 09:16 AM   #20
Nikatrel
First problem at 51,000k miles - Had to replace ignition coil on cylinders 3 and 2, cost $550
Second problem at 66,000k miles - Had to replace ignition coil on cylinders 4 and 1, cost $550
Third problem at 78,000k miles - Threw a rod bearing and f***ed up the block, replacing with a new 40k mile motor. cost $2500, its still in the shop from this incidence.
I hate my car, its the 2.4L 2001 GL
