Go Back   Aleromod.com > General Help > Product Reviews
Old 10-24-2005, 04:29 PM   #1
Matthewfinlay04
Started using this since the day it came out. I started with the 5w30 but noticed that I was burning about a qt every 1,500 miles. So the second time I changed it out I used 10w30 and the problem solved. You can get the 5qt jug at Wal-mart for around 24 bucks. So I think that its well worth it. Use it with a super-tech filter so total cost is around 27 dollars. Which isn't bad considering jiffy-lube starts at 20 for dino oil. Last oil change had 5,000 miles on the oil and it was still looking brand new, not dark at all. Only changed because when changing the water-pump some coolant go into the dipstick hole. Have noticed a huge difference in oil color and smell from switching from MAXLIFE. First time I used the oil it had a dirty appearance 1500 miles in. Each time since then it seems like stays cleaner longer. Special thanks to the extra detergent and super-syn.
