Old 10-27-2005, 08:54 PM   #1
keepitsimple
sorry for all these questions but i really want to finish my turbo kit and to do it right, and i might need a new fuel rail and lines does ne1 know where to get high flowing fuel rail and lines or other fuel upgrade for my kit, do i need a new pump or is it strong enough i want to eventually run 18 psi
Old 10-27-2005, 09:48 PM   #2
Oldsman
Owner
Oldsman's Avatar
fuel rail = venom or rksport. don't really need.
fuel pump = walboro 225 pump. not a bad idea.
fuel lines = make your own. but not needed.
AFPR = Accell or casper. a need.
Fuel pressure gage also needed with the regulator.
Beware of the BackStabber
Old 10-27-2005, 10:00 PM   #3
anything you need bro, just let us know...referring to the 2.4, ask the old man....errrr, oldsman and he can hook you up.
Old 10-27-2005, 11:28 PM   #4
keepitsimple
sweet thanks guys glad to see this forum is so helpfull and friendly, thanks for the advice,
Old 10-27-2005, 11:31 PM   #5
mfuller is the man for suspension and brakes and silentalero is the guy if you want to add anything ricey to your car....LOL, like neon blue washer nozzles....hahahahahaha
Old 10-28-2005, 01:48 AM   #6
Spilner521
Boost Guru
Spilner521's Avatar
what size turbo are you using and how much boost will you be running to start?
fuel mods on a turbo engine all depend on how much air is going into the engine. a new fuel rail and lines you wont really need, the stock pieces flow pretty well. depending on what type of fuel mods you want to use, an adjustable fuel pressure regulator could help you out a lot, as oldsman mentioned. if you're using an FMU, you'll need that walbro pump for the higher fuel pressures. if you dont plan on raising the fuel pressure above stock, the stock pump will flow enough for 10-12psi. my setup uses 4 extra injectors in addition to the 4 stock injectors. the complete stock fuel system is in place (including FPR) and there is a T fitting on the fuel feed line that leads to a fuel block, which distributes the fuel evenly to the additional injectors. i can drive around all day off boost and the car runs completely normal like stock. as soon as i hit boost, the extra injectors flow the extra fuel.
there's a few different kinds of setups you can. make sure you do a lot of reading and learning before you tear apart your car. any questions feel free to ask anytime
