The easiest way I have found to run the power wire through the grommet is to use a clothes hanger fully extended and poke it through and use it to pull the wire through. Otherwise, as Kampfer said, you're going to have to crawl under your car where as this way you can just pull the clothes hanger up and you're good to go.
Also if you're going to replace or have plans on replacing your rear speakers, now would be the time to do it while you have part of the back of the car torn apart. If you really want to get the power wire hidden and installed correctly you are already going to be back there, so why not just make 1 big mess and do it all right rather than tearing it apart again?
