LIM is off, just have to clean the mating surfaces and then I'm onto putting stuff back together :D
1 Attachment(s)
Done for the night until I can find an inch-lbs torque wrench tmrw... the one I rented is in ft-lbs and I misread it at the store. :(
On a side note, is it normal for injectors to have a little 'ring' around the top? It looks burned; I couldn't get it to come off with carb cleaner. External image link: http://i28.tinypic.com/66zvci.jpg |
^^^yes
Okay, never pulled my injectors before so it struck me as odd. Thanks! |
did you remember to do your oil pump o-ring?
No, I followed the walkthrough and saw no mentions of an oil pump o-ring. :(
i couldn't get mine out... so i left it.
You don't need to bother going to get another torque wrench, just convert the inch-pounds to foot-pounds and vise versa. There is a conversion chart in the Haynes manual if you have one. I can't remember the exact number off the top of my head. When I did my LIMG my injectors looked the same way. I just cleaned them up with some solvent and went about my business. As long as they don't leak you are in the clear.
by the way, those fuel lines have special tools to remove them lol for future reference
Lol come on im not that bad.. the wrench only went down to about 60 ft lbs at its lowest point. It wasn't usable for the limg application. |
Oh gotcha, did you get one of the big ones? I have the small $20 on that goes really low. I had to borrow my father in laws huge torque wrench when I was messinn with my struts.
Yep, it was the only one autozone rented. I ended up going to sears and buying an inch-lbs one for $80... I'll be returning it sometime this week :lol: |
