Old 08-14-2009, 06:23 PM   #1
jrim
jrim's Avatar
jrim is on a distinguished road
Send a message via AIM to jrim
LIMG repair... stuck again :D
So I've got everything off of the top end, except one bolt on the LIM, blocked by... part of the fuel rail. Yes, I'm having problems with the fuel rail, AGAIN
I have REMOVED the nut circled in red from the fuel rail. However, the physical line that the nut is attached to, which feeds into the fuel rail, doesn't seem like it wants to come out. I need to get the line out so that I can access the bolt.
Do I just pull on this line, pulling it toward the driver side wheel? It doesn't feel like it wants to come out, and being that it is a metal fuel line, I'd rather not snap it.
Judging by this pic from the LIMG repair walkthrough, I'm assuming the line comes out, but how?
Thanks
2002 Alero 3400 4 door
jrim is offline   Reply With Quote
Old 08-14-2009, 06:25 PM   #2
You at your house? Maybe I'll stop by and check this out, lol.
Old 08-14-2009, 06:26 PM   #3
jrim
jrim's Avatar
Yepp lol. Give me 15mins if you really are, I'm about to hop in the shower.. sitting over my car all day has created a nasty odor.
Old 08-14-2009, 06:29 PM   #4
Sure I'll stop by. I need a second hand with something on my car anyway.
Old 08-14-2009, 06:36 PM   #5
I'd offer help, but i can't see the pics. if you can move them to the upload on site, then i can. if not, you'll have to wait till, at least 9pm
Old 08-14-2009, 06:46 PM   #6
jrim
jrim's Avatar
Lol sure thing, come on over, I thought I was waiting on someone else for something so I showered but I have more time now.. I'm free till about 8ish. You still have my address in paypal?
Old 08-14-2009, 06:50 PM   #7
jrim
jrim's Avatar
For cher:
Old 08-14-2009, 06:50 PM   #8
bkathsalero
bkathsalero's Avatar
bkathsalero is on a distinguished road
Send a message via MSN to bkathsalero
wiggle and spin the fuel rail, but first you have to disconect the harness and all that. but while twisting it pull fuel rail towards passanger and line towards driver. and that bolt can be a pain in the ass usually it takes a universal
bkathsalero is offline   Reply With Quote
Old 08-14-2009, 06:54 PM   #9
jrim
jrim's Avatar
Disconnect the harness... so I need to pull the injectors out? Or try? Because that fuel line that's still attached is pretty much preventing the fuel rail from doing much moving.
Old 08-14-2009, 06:55 PM   #10
is that bolt one of the angled LIM bolts?
I left my fuel rail in place.
hmm... that might have been the one that i used a wrench to get, instead of a socket.
Old 08-14-2009, 06:56 PM   #11
jrim
jrim's Avatar
Yep, I believe the new torque specs refer to it as one of the "vertical" bolts.
Old 08-14-2009, 07:04 PM   #12
bkathsalero
your first step is to get that other line off
Old 08-14-2009, 07:11 PM   #13
mfuller
You know, you don't even have to disconnect the fuel lines....
Just undo the clamp that holds the feed and return lines to the cylinder head, unbolt the fuel rail brackets from the LIM, and remove the fuel rail and injectors as one assembly. Use tape or something else to tie it out of the way so you cantake the LIM off. This is how dealership techs do it.
Old 08-14-2009, 07:15 PM   #14
bkathsalero
/\/\ I'm pretty sure he's right cuz thats how stan the tech next to me does it to i believe, but I just pull everything
Old 08-14-2009, 08:02 PM   #15
jrim
jrim's Avatar
Good call mfuller, undoing the clamp definitely helped. The fuel injectors were being stubborn and I'm not really looking to get much dirtier tonight so I'll probably finish yankin the rail out tmrw. Thanks again.
Old 08-14-2009, 08:13 PM   #16
there ya go.
you are using the gagt write up, as your how to.. right?
Old 08-14-2009, 08:23 PM   #17
the noob didn't even see the little nut on the bracket on the side of the LIM lol
btw jrim that was like 70% throttle
Old 08-15-2009, 02:25 AM   #18
jrim
jrim's Avatar
Lol hey. I would have noticed it tmrw. Staring at the same thing for hours... you tend to over look the simple solutions.
70%? You're lyin lol that car is nasty. Build mine like that.
Old 08-15-2009, 03:11 AM   #19
High five that's how I did it
Old 08-15-2009, 06:57 AM   #20
greg_gorrell
greg_gorrell is on a distinguished road
+1....
havent done before but i thought mine went and planned on doing this way. ordered the kit but luckily it was my water pump.
greg_gorrell is offline   Reply With Quote
