03-25-2004, 11:29 PM
On the gls there is a little compartment in fornt of the shifter. In this compartment there is a light bulb that is on and i was wondering what type of bulb this was so i could try and change it to a blue......any ideas on what type and size this bulb would be?
03-26-2004, 12:00 AM
i believe it's a 212-?, i turned all my interior lights to blue and instead of buying them i went and bought sharpie permanent marker in blue and colored all of my bulbs.... works absolutely great with no peeling
03-26-2004, 01:33 AM
Replaced it with LEDS.
03-26-2004, 11:42 AM
ditto
A little bit will set you free.
Pheenz Motorsports Founder
03-26-2004, 01:08 PM
How did you replace them with LED's?? How did you make them fit and where did you find them?? Did you get the LED's off Oznium.com? Thanks
03-26-2004, 01:15 PM
I ordered them from oznium. Take out the radio bezel and the light comes out with it. Find you positive and negative wires, splice/solder according to ozniums directions and your set. As far as making them fit, they are really small.
03-26-2004, 03:29 PM
Same method. Only thing different is wrap the two led's with electrical tape, to kind of make them fit in the hole.
03-26-2004, 03:40 PM
Thanks everyone fro you answers im looking into all those options....thanks again
03-26-2004, 03:45 PM
I did the LEDs too, but I do recall someone else asking this before and someone else (maybe Nick) said that you can't get a replacement bulb for that. I guess the little clip and the bulb are all together or something like that. So any kind of replacement is going to be somewhat custom. Any bulb/LED will work, you'll just have to figure a way to hold it in place.
03-26-2004, 03:55 PM
The Founder
LED is the way to go in the cubby hole. I also wired mine to a switch so the SOB doesn't stay on at night all the damn time.
03-26-2004, 07:47 PM
I Love Tiara!
will a 194 bulb fit into the rear side marker
03-28-2004, 10:08 PM
I had a light bulb question: what are the fog light bulb numbers? (for the stock fog lights) and what are all the bulb numbers for the headlight assembly, i know theres 9005,9006, but what are the other 2!?
AUTOBOT
03-28-2004, 10:35 PM
oh yeah does anyone know where i can buy yellow LED's just like the little individual ones from oznium?  h34r: thanks
AUTOBOT
03-28-2004, 10:44 PM
The outer turn signal bulb is a 194 and the inner is a 3157. If you put a LED 194 in your turn signal, don't bug out when it starts blinking faster. The LED just uses less voltage, so it blinks faster.
03-29-2004, 01:03 AM
If not from Oznium you can try radio shack
03-31-2004, 05:24 PM
i still need to know the light bulb number for the stock foglights, anyone know?
AUTOBOT
03-31-2004, 05:35 PM
The Founder
03-31-2004, 08:41 PM
im having some trubble on trying to find replacment bulbs for the foglights, cause i was thinking about makign those bulbs yellow, and puttign in new foglights or just put in some blue bulbs, i dunno yet but help me out with a link for foglight bulbs, thanks
AUTOBOT
