01-30-2008, 09:38 PM
superchargers
what's a fair price for a super and what do you guys mean by a software update?
thnx
01-30-2008, 09:50 PM
Depends on what engine you have..
2.4L: I got mine for $1579 shipped.
2.2L: Depends, but looking at $2200+ generally
3.4L: Generally nonexistant, expensive if you do find one or custom build one.
01-31-2008, 01:30 AM
is it simple to install? i'm just beginning to learn about cars.
what's the reflash and where do i get it done?
thanks
oh yeah, i have a 2.2
01-31-2008, 06:02 AM
The Eco's install's a little more complicated but they all come with detailed instructions step by step.
Reflash is a re-tune, the dealership puts a new tune on your car so your computer can read and compensate for boost.
01-31-2008, 07:57 AM
I thought that dealers wouldnt do n-bodys.
2003 Alero
2.2 5speed
Grey
1996 GMC Yukon 4x4
01-31-2008, 08:45 AM
They wont do a 1999 N-body. Go figure.
01-31-2008, 12:51 PM
ahhh cool.
2003 Alero
2.2 5speed
Grey
1996 GMC Yukon 4x4
01-31-2008, 12:58 PM
Or Ecotecs... Or at least nobody has tried and there is no calibration for it.
01-31-2008, 01:23 PM
^^My thought, I think theres no reflash available for the ecotec from the dealer.
02-01-2008, 01:23 AM
There is for a J-Body though. I guess you'd need a HPTuners setup and work off that.
02-01-2008, 09:40 AM
If you were planning on doing anything major to the motor then wouldn't it be a good idea to get hp tuners first, learn how to use it and tune properly, so that you could fine tune everything on your own?
2003 Alero
2.2 5speed
Grey
1996 GMC Yukon 4x4
02-01-2008, 11:24 AM
yes, or go get it dyno tuned because you have to use a dyno anyway, why not get a pro job for $4-700
02-01-2008, 12:42 PM
http://www.aleromod.com/forums/showthread.php?t=20529
this will help you out, this is what i did to mine and my car is running just fine.
that is if you have a 2.4 ld9 motor.
