Old 04-22-2008, 09:33 AM   #1
JOEY GLADSTONE
JOEY GLADSTONE is on a distinguished road
raise idle?
ive been having voltage problems with my car and if i could raise the idle about 150rpm it would fix everything, my engine doesn't seem to idle at the right RPMs because the whole engine like shakes at idle and i was just wondering if theres anyway to change the idling RPMs since everything on the TB is automatic
JOEY GLADSTONE is offline   Reply With Quote
Old 04-22-2008, 09:41 AM   #2
besides the throttle body idle set screw
screw it in slightly, it pushes the butterfly open
Old 04-22-2008, 09:44 AM   #3
JOEY GLADSTONE
i dont think that it has an adjustable screw on it, i think its just something crimped onto the end of the throttle cable
Old 04-22-2008, 10:12 AM   #4
Old 04-22-2008, 01:49 PM   #5
super white alero1
Trying to get it together
super white alero1's Avatar
you should first try to clean the IAC valve A black valve located on the throttle. That's the normal case of surging idle.
