Old 05-01-2006, 02:17 PM   #1
Menace
@Kutztown University PA
Menace's Avatar
Menace is an unknown quantity at this point
Send a message via AIM to Menace
When I drive I heard a loud constant squeeking noise on my front driver side wheel. I re tightened the lugs and it still made the noise then I washed out the wheel with my hose ( thoguth maybe somthing got caught in there). Well the noise stopped for about 5 minutes then it started again. Does anyone know whats going on ? Maybe my wheels arent getting any brake fluid because I havent filled it up a long time and its still full to the line. If so how do you bleed them ?
Alero is sold!
2007 Scion tC in driveway!!
Stuff for sale
http://www.aleromod.com/forums/showthread.php?t=13919
Menace is offline   Reply With Quote
Old 05-01-2006, 02:26 PM   #2
battistoni21
battistoni21 is an unknown quantity at this point
Send a message via AIM to battistoni21
possibly your hub? Just a suggestion, im not sure.....
battistoni21 is offline   Reply With Quote
Old 05-01-2006, 02:48 PM   #3
need brakes?
Old 05-01-2006, 03:34 PM   #4
Menace
Menace's Avatar
I put on new brake pads and rotors like 1000-3000 miles ago
Alero is sold!
Stuff for sale
Old 05-01-2006, 05:03 PM   #5
Menace
Menace's Avatar
I bled the brakes which was easy as hell if anyone needs to know how to do it just ask me ill help yah out. It worked fine for like 30 mins then started to squeek again maybe after 30 mins air got pushed down into the hosing again.
Alero is sold!
Stuff for sale
Old 05-01-2006, 05:39 PM   #6
brsexton
brsexton is an unknown quantity at this point
Send a message via AIM to brsexton
What kind of brake pads did you use? It may be the metal in the pads doing it. I had this happen with the pads on my old car. You should take the pads off and run some sand paper over them.
2005 Honda CR-V AWD
brsexton is offline   Reply With Quote
Old 05-01-2006, 06:14 PM   #7
alerotuner99
make sure the metal slides where the pads sit at aren't touching your rotors. My car was making a screeching noise a week ago and the slide was touching my one rotor so i bent the slide out of the way and no more noise. It also could be your wheel bearing goin bad but i'd check the easy stuff first.
Old 05-01-2006, 08:31 PM   #8
Menace
Menace's Avatar
I use bendix ceramic pads, I havent heard the squeeking noise for a while I think the brake bleeding worked.
Alero is sold!
Stuff for sale
Old 05-01-2006, 08:34 PM   #9
alerored04
alerored04's Avatar
I have the exact same pads and i hear no squeaking, bleeding it probably helped a lot.
My car breaks alot.
Old 06-20-2008, 09:38 AM   #10
zzyzzx
zzyzzx's Avatar
OK, how do you bleed brakes on this car? I've never done it on a car with ABS. I've done it on a non-ABS car lots of times.
Old 06-20-2008, 09:41 AM   #11
bad lol
Old 06-20-2008, 09:46 AM   #12
surreal_awakening
surreal_awakening's Avatar
surreal_awakening is on a distinguished road
Send a message via Yahoo to surreal_awakening
Thanks for the Madden-like illustration, ion LOL
surreal_awakening is offline   Reply With Quote
Old 06-20-2008, 10:18 AM   #13
cliffordwoeller
You got beat by an Alero!
cliffordwoeller's Avatar
cliffordwoeller is on a distinguished road
Send a message via AIM to cliffordwoeller Send a message via MSN to cliffordwoeller Send a message via Yahoo to cliffordwoeller
lol thats funny another one comes back from the dead
cliffordwoeller is offline   Reply With Quote
Old 06-20-2008, 10:23 AM   #14
you'll probably want to ask that question... to a member WHO IS STILL ON SITE!
Old 06-20-2008, 11:27 AM   #15
Diieee Zombieeee
Old 06-20-2008, 11:38 AM   #16
Vinalero
Vinalero's Avatar
Actually, that proves he used the search button. Isnt it what everyone ask to do before starting another tread?
Old 06-20-2008, 11:46 AM   #17
ya but his question is a new issue unrelated to this thread, should've just posted a new thread
but anyways you just loosen the bleeder screw and uh, bleed em. nothing special as far as i've seen.
Old 06-20-2008, 11:57 AM   #18
Alerosaint
Gone but not forgotten
Alerosaint's Avatar
Alerosaint is on a distinguished road
Send a message via AIM to Alerosaint Send a message via Yahoo to Alerosaint
Diieee Zombieeee
lol....you stay kiling zombies...straight out of Resident Evil huh?
Alerosaint is offline   Reply With Quote
