Old 07-07-2008, 11:33 PM   #1
cliffordwoeller
You got beat by an Alero!
cliffordwoeller's Avatar
cliffordwoeller is on a distinguished road
Send a message via AIM to cliffordwoeller Send a message via MSN to cliffordwoeller Send a message via Yahoo to cliffordwoeller
is this the thermostat housing ?
ok so i am trying this again... what you see is the back side of the exhaust manifold near the fire wall... the cam is pointed in between the gaps of the E.M. what i have circled i am guessing is the thermostat housing. if it is how do i get to it. the E.M. is in my way on top and at the bottom the oil pans right there.. i am so tired of fighting with this thing and am really about tired of trying to do things to this alero and it just not working for me but some help would be much appreciated
cliffordwoeller is offline   Reply With Quote
Old 07-07-2008, 11:51 PM   #2
cliffordwoeller
maybe a lil help ?
Old 07-08-2008, 02:20 AM   #3
On the 2.4 it's right there going up on the back of the water pump housing.
Old 07-08-2008, 02:43 AM   #4
cliffordwoeller
i dont know where that is i am still trying to get familiar with this engine
Old 07-08-2008, 04:42 AM   #5
GA_turbo
GA_turbo's Avatar
GA_turbo is on a distinguished road
its very easy to do, for the looks of it you have one of the screws of already out now for the other screw you need a 1/4 inch extencion and a 8mm sock it, then once you got them screws off you want to go under the car and loosen up a 13mm bolt thats holding the metal pipe to the oil pan, once thats off you can pull the pipe down and the thermostat will come out. when yo put the new one on make sure the thermostat sits in there with the weight up..ok, you will be able to put it back on with no problem from the top of the car by your self, dont forget to get the gasket for it also, its just an o-ring.
well hope that helped, if not ill try to get some pics on how to do it
GA_turbo is offline   Reply With Quote
Old 07-08-2008, 10:22 AM   #6
cliffordwoeller
ok i think thats gonna help
