Old 09-15-2008, 08:40 PM   #1
Turbo Qs
As I've been reading everyones' threads on it, i still feel incredibly noob-ish.
And i'm not exactly looking for strictly 100% accurate numbers or figures, but...
Could someone compile a sort of list, or something, showing how much boost yields approx what horsepower, and what engine mods you'd have to do in order to NOT have your car explode?
Obviously it varies car to car, even with the same engine, and wear and tear is going to vary, thus causing premature breakdown of other parts that might not be listed...
But i figured it could be a decent general DO-ALL reference for new members (or old members new to turbos) to get a decent idea of what they are looking to do, or how MUCH of a project it really is.
it would also be a nice addition to the wiki, if it turns out well...
Old 09-15-2008, 08:41 PM   #2
No, lol. Each turbocharger is different, sizing, flow, varies, there is no direct relation of PSI (flow resistance) to maximum capacity before things break, only vague guidelines.
There's an excellent new writeup of a complete turbo parts list and installation pictures on j-body for an LD9 setup at least. I'll get that edited and transfered to Aleromod Upgrades soon.
Old 09-15-2008, 08:47 PM   #3
super white alero1
Trying to get it together
super white alero1's Avatar
How much you want to spend? How fast you want to go? How long you wish to keep your car? Ask yourself those question first.
Edit: Cheap, fast, reliable....Pick two
MODS:???
Old 09-15-2008, 08:49 PM   #4
jackal2000
Keepin it Real
jackal2000's Avatar
cheap, fast, reliable. pick two.
damnit superwhite, no more editing posts for you.
2015 Audi SQ5
Old 09-15-2008, 08:51 PM   #5
Midgear
on vacation
I pick Fast and Reliable.. now make me a list lol
WILL NEVER FORGET
Old 09-15-2008, 08:56 PM   #6
obviously each turbo is different, but there'd HAVE to be a direct relationship to what psi produces approx what Hp gain.
as well as for our cars, what a basic setup would run, parts wise.
its not like i haven't read countless threads on "what do i need for this setup?" with people typing out a laundry list of parts. Its certainly possible to do a basic guideline.
If they can do it for general health (that varies greatly from person to person) i think it can be done for a machine that was assembled the same way.
I'd say if it was to be done, go for reliable, period. Cheap, you can find yourself and fast, you can do more research for.
Old 09-15-2008, 09:03 PM   #7
super white alero1
Forged lower compression pistons - $$$
Forged H-beam rods or Billet rods from Mantaparts - $$$
Clevite bearings - $$$
Oiling system - $$$
Turbo unit - $$$
Intercooler - $$$
Methol/alcohol injection - $$$
Tuner system - $$$
By-pass valve - $
Head job - - $$$
Valve job - $$$
Dual coil spring (rate @ least 300 lb) - $$
SS valves - $$$ or Titanium valves - $$$
Bronze guide - $$
SS retainer - $$
Followers - $$
2.3 HO oil pump - $$
short block modification - $$$$
Oil pan oil modification - $$
Exhaust work - $$$
Intake piping - $$$
Somebody to tune the sh*t outta the engine - $$$
Dyno pull - $$
Watch your tranny crack on the first try at the track - PRICELESS
Don't forget to upgrade brakes transmission, suspension,
EDIT: PIE
MODS:???
Old 09-15-2008, 09:07 PM   #8
alerored04
alerored04's Avatar
Cherry the problem with this is that turbo systems can differ not only in PSI but in flow as well. Think of it in wiring terms. PSI would be resistance equivalent to ohms where flow and system volume would equate to voltage. So even though two turbo systems may both run 10 psi one may be pushing that through a 3" pipe while the other is running 2". The CFM flow on the 10 psi 3" would be much larger hence more power despite both being at "10 psi" hence psi is a tough way to determine power output of a setup. And I am not even touching on the differences tuning make. If I had first hand experience I would try to answer your question in a specific way but coming from me would be all speculation.
My car breaks alot.
Old 09-15-2008, 09:13 PM   #9
super white alero1
^^^ alerored, I'm jealous of your mods :P
MODS:???
Old 09-15-2008, 09:21 PM   #10
thats why i said just a general list. Obviously, anyone who followed it and said i have X setup, now i'm running 260hp would be a fool. Each and every car differs, even if running the exact same equipment. Hence why frostbite ran 14s in the 1/4 mile w/ minimum mods...
thats why i said GENERAL.....
GENERAL!
Edit: superwhite.... thats alot of $s
Old 09-15-2008, 09:38 PM   #11
Midgear
on vacation
Oiling system - $$$
Bronze guide - $$
SS retainer - $$
Followers - $$
EDIT: PIE
that edit was well worth it. now all hilarity aside-
the things I quoted you on.. can you explain what these parts do / their use in this "setup" .. I removed the things I personally know about.. these other things like "Followers" ... wtf is that?
WILL NEVER FORGET
Old 09-15-2008, 09:49 PM   #12
I've never heard of followers, unless he means those who follow your progress. Always need those.
Bearings are what the rod/crank spin on, good to have high quality ones. Oiling system upgrades are nice to make sure everything is oiled. Meth injection cools the charge air and allows for more aggressive timing in tuning. Springs, guides, retainers, all head crap to improve the performance of the valves opening and closing, quickness to react, not necessary. The high output oil pump as stated above, good idea to improve oiling. Short block mods for oil feed line and tapping oil pan for oil return line.
Old 09-15-2008, 10:08 PM   #13
super white alero1
This quote explains better than me
The hydraulic lifter comprises a cam follower that is moved up and down by contact with the cam profile, and an inner bore into which the valve lifter is closely fitted and retained by a spring clip. The valve lifter, in turn, is a cup closed at the top by a freely moving cylindrical plug that has a socket at the top to fit the lower end of the pushrod.
I would've assume that Ion would have used followers instead of the stock rotator. They periodically show up in JBO classified.
The benefit of such a setup is not noticeable for power but reliability since rotators don't react fast enough depending on what your redline is. Followers uses bearings and therefore response faster.
The reason most people don't do this is because its worthless unless you plan to do circle track, road course , or endurance.
Does it make sense why I got all those suspension/brake crap now.
MODS:???
Old 09-15-2008, 10:16 PM   #14
Dude, these don't have freaking rocker arms. DOHC. LD9. Not pushrod V6. There's no such thing as "followers" in my engine.
Just like my uncle who was surprised I wasn't going to get roller rockers. Overhead cams directly actuate the valves by pressing against little dome shaped "lifters" on top of the valve stem ends.
The ones you see go up on j-body are likely the old pushrod 2200 OHV crap engine ones.
Old 09-15-2008, 10:31 PM   #15
super white alero1
ion you question me as if i don't know what I'm talking about and you skim everything i post. Did you take a minute to follow what i meant.
Here's an image of what I'm talking about. If you went as far as me in research you would have found this.
Edit the little dome shaped lifters you talking about are rotators. Our engine don't have lifters.
MODS:???
Old 09-15-2008, 10:35 PM   #16
Oh, lol. Now it makes sense. I didn't know wtf "followers" or "rotators" were.
The Overhaul Manual calls them lifters on the LD9. So does spyhunter and practically everyone on j-body.
Old 09-15-2008, 11:14 PM   #17
super white alero1
@ midgear
Clevite bearings - the best and highly recommended bearing on the market.
Oiling system - See short block mod
Methol/alcohol injection - To help cool down combustion temp, to help prevent knocking
Dual coil spring (rate @ least 300 lb) - This help shift your redline up higher to prevent valve float.
Bronze guide - Aids in cooling of the exhaust valve. Also the bronze guides are more frictionless than stock guides
SS retainer - lighter than stock, less rotation mass
Followers (rotator) - are more frictionless to better aid in moving parts
2.3 HO oil pump - see short block mod
short block modification - This is something you need to talk to machinist about. Used with 2.3 oil pump, and delete the balance shaft. I'll have some pic up
Oil pan oil modification - Depends how serious you go. A dry sump is recommend for hard core racing, but it depends on you.
MODS:???
Old 09-15-2008, 11:21 PM   #18
Cherry.....there's no such thing as what you're asking for.
you can take the same turbo and put it on two different cars and get two differrent sets of numbers.
Factors it depends on:
Overall flow
Fuel grade
Altitude
Tune
Valve size
Intake path size/smoothness
Condition of compression rings
Total ignition system
and the list goes on and on.
I can take a t3/t4 at .57 trim, .63 AR and make 200hp on one engine, and 300 on another.
A well maintained high-mileage engine may withstand 300hp, while a hard-beaten low mileage engine might blow at 250.
I think you get the point.
Old 09-15-2008, 11:24 PM   #19
Quite a few on here had theirs blow with no mods at all, heh. Depends on a lot.
Old 09-15-2008, 11:34 PM   #20
Midgear
on vacation
@ super_white_alero1
that's the kinda response I was lookin for now for the pics-
WILL NEVER FORGET
