Old 09-24-2008, 03:39 PM   #1
Mach1
Mach1's Avatar
Mach1 is an unknown quantity at this point
Service engine light... could be O2 sensor
Hey guys, i just hit 90k a little while ago and lately (under hard acceleration) the motor stumbles. I checked the servce manual for a diagnosis for the hesitation, and the first thing it listed was O2 sensor replacement. And now, the service engine light just came on last night. I tightened the gas cap just to make sure it wasn't a fluke and it seems that it's not. So have any of you guys had this problem and was it solved with a new O2 sensor? Also, I have the V6.
'99 Alero GLS Sedan - Gold, V6, 17x7 Enkei PK6s,
SLP Catback, Eibach springs
Mach1 is offline   Reply With Quote
Old 09-24-2008, 03:48 PM   #2
surreal_awakening
surreal_awakening's Avatar
surreal_awakening is on a distinguished road
Send a message via Yahoo to surreal_awakening
I would say go to Autozone or Advance Auto or one of those parts stores that reads codes for free and see what code it's throwing before jumping to any conclusions.
surreal_awakening is offline   Reply With Quote
Old 09-24-2008, 03:57 PM   #3
01oldsgls
01oldsgls is on a distinguished road
motion seconded
01oldsgls is offline   Reply With Quote
Old 09-24-2008, 04:06 PM   #4
AGT
AGT's Avatar
Either O2 sensor or cam position sensor.
Have a good day
Old 09-24-2008, 04:27 PM   #5
spark plugs (misfiring)
must read code
Old 09-24-2008, 05:36 PM   #6
Mach1
Mach1's Avatar
I wish I had a scanner. If anything, I'll purchase a new O2 sensor and replace the old one and see if that fixes the problem. If it doesn't, then i'll just have my have my mechanic use his to find the problem. But thanks for the help everyone.
Old 09-24-2008, 05:37 PM   #7
Mach1
Mach1's Avatar
this is new to me though that autozone will do it for you. ill try that.
Old 09-24-2008, 05:38 PM   #8
AGT
AGT's Avatar
Autozone for a free code read
Nearest LocationsMilesAddress
Location Info 3SW 15300 19 Mile Rd
Clinton Township, MI 48038
(586) 226-8681
Get Map and Hours
Get Directions4SE 388 N Gratiot Ave
Clinton Township, MI 48036
(586) 468-5295
Get Map and Hours
Get Directions5E 51301 Gratiot
Chesterfield Twp, MI 48051
(586) 949-7068
Get Map and Hours
Get Directions5W48940 Van Dyke
Utica, MI 48317
(586) 739-4325
Get Map and Hours
Get Directions6SE 36727 Gratoit
Clinton Township, MI 48035
(586) 790-8874
Get Map and Hours
Get Directions10S 28401 Groesbeck Hwy
Roseville, MI 48066
(586) 777-6665
Get Map and Hours
Get Directions10SW 2702 Metropolitan Parkway
Sterling Heights, MI 48310
(586) 795-0701
Have a good day
Old 09-24-2008, 05:44 PM   #9
how much are o2 sensors?
Old 09-24-2008, 05:50 PM   #10
jackal2000
Keepin it Real
jackal2000's Avatar
around $90.
2015 Audi SQ5
Old 09-24-2008, 06:02 PM   #11
wait you're in MI, get over here I'll scan it with HPTuners
Old 09-24-2008, 06:19 PM   #12
Don't throw money at the problem before you know what it is.
Plus you'll need a scaner to delete the code anyway
Old 09-24-2008, 07:00 PM   #13
CactusWill
Right. I spent $300+ replacing the oxygen sensors, did a complete tune up with plugs and everything, and then it didn't even fix the problem, it was the catalytic convertor.
Old 09-24-2008, 10:05 PM   #14
undecided02
undecided02's Avatar
undecided02 is on a distinguished road
could be MAF too. Buy buddy had his go on his S10 and it pretty much did the same thing. Whatever u do dont let a shop install it, they will charge a ton and its about the easiest thing to install. Also I bought an OBD2 code reader a few months back and it is the best investment I have ever made, seriously consider getting one.
undecided02 is offline   Reply With Quote
Old 09-24-2008, 10:48 PM   #15
Mach1
Mach1's Avatar
Well, I had autozone scan it and it turns out that there was a misfire in cylinder #2. Now i just changed the plugs and wires less than a year ago so it can't be that. It has to be the coil, maybe corrosion on the contacts. The guy over at Autozone also said that it could be the injector too, but i'm having a hard time seeing how an injector would cause a misfire.
Old 09-24-2008, 11:10 PM   #16
Not enough fuel mixture
Pull out #2 and look at it, see if it's fouled
Old 09-25-2008, 12:32 AM   #17
alerored04
alerored04's Avatar
If plug #2 is white then it would be a clogged injector meaning lean, if it is fouled as Redog stated then your injector is leaking causing you to run rich, which seems more likely to me as lean normally doesn't misfire like rich will.
My car breaks alot.
Old 09-25-2008, 01:26 AM   #18
Man, that thing still better work when i get it back
Old 09-25-2008, 09:39 AM   #19
super white alero1
Trying to get it together
super white alero1's Avatar
Linky linky
MODS:???
Old 09-25-2008, 02:08 PM   #20
Mach1
Mach1's Avatar
swwweeeeeet
