Old 03-11-2009, 03:13 PM   #1
itsbmw
big 3,
Old 03-11-2009, 03:40 PM   #2
itsbmw
Old 03-11-2009, 03:42 PM   #3
Beholder88
Beholder88's Avatar
You need to use two 13mm wrenches, one on each bolt. Can't really do anything about the wire twisting with the bolt, just have to find a way to get it to work.
Old 03-11-2009, 03:56 PM   #4
itsbmw
Old 03-11-2009, 03:59 PM   #5
Beholder88
Beholder88's Avatar
If you can get a pair of pliers SAFELY onto the bolt closest to the alt then it should do the same thing, or two pairs of pliers... Improvise man just don't break anything.
Old 03-11-2009, 04:03 PM   #6
itsbmw
Old 03-11-2009, 04:07 PM   #7
that is the most important line in the upgrade lol without it you just upgraded the grounds on your car but not the power
Old 03-11-2009, 05:03 PM   #8
itsbmw
Old 03-11-2009, 05:36 PM   #9
Misuseofyou
Misuseofyou's Avatar
Misuseofyou is on a distinguished road
When I did this it was so cramped and close in there I didn't even attempt to take the bolt right out. Instead I clipped off the end of my ring terminal, and made it a spade. Loosen the bolt, slip it in and tighten.
Misuseofyou is offline   Reply With Quote
Old 03-11-2009, 06:53 PM   #10
Try putting a 1/2" Open end wrench on the alternator side and a 13mm socket on the nut.
13mm= .511", .5" = 12.7mm- and wrenches are always a bit over. Should work
Old 03-11-2009, 09:12 PM   #11
itsbmw
Old 03-11-2009, 10:06 PM   #12
Originally Posted by itsbmw View Post
I am not leaving aleromod tho.
damn.
we were so close
Old 03-11-2009, 10:08 PM   #13
itsbmw
damn.
we were so close
eff you
Old 03-20-2009, 12:44 AM   #14
Alero_1986
Alero_1986's Avatar
Sorry to thread Jack. But since you are no longer an alero owner I think it is fair game
Is the alternator fused? Or is the new wire directly connected from battery + to alt?
Old 03-20-2009, 12:51 AM   #15
no its directly from the batt to the alt.
and also thread jack, does this upgrade really make that big of a difference? cause i have a serious power need problem with my system
Old 03-20-2009, 07:20 AM   #16
its directly connected. when you upgrade, you CAN put a fuse inline, but you don't need to.
yes, it makes a huge difference.
Old 03-20-2009, 10:06 AM   #17
Considering the stock wiring is equiv of 10 ga. hell yes its a huge upgrade, noticeable AND measurable.
Old 03-22-2009, 10:21 PM   #18
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
what it the big 3 other then gm ford and chrystler
Old 03-22-2009, 10:33 PM   #19
Misuseofyou
I know for a fact you've read and posted in threads about this upgrade. Were you dropped on your head or something? Do a search already.
Old 03-22-2009, 11:04 PM   #20
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
heads amps and subs is what ive posted about i think is that it
was wondering what the Big 3 was becasue of the title of this forum, reading it it didnt seem to realate to 3 anything
