03-20-2009, 11:01 AM
3.4l Swap From A 2.4l
Is it possible to swap my knocking 2.4L motor for a newish 3.4L motor? and will the transmission still work. I know that I would need to make some mods to the exhuast and such but will it work? Sorry Im a noob when it comes to this stuff.
03-20-2009, 11:12 AM
You don't want a 3400. Just swap in a working 2.4L. Or a built one.
03-20-2009, 11:26 AM
3400 BAD 2.2L Good
03-20-2009, 11:48 AM
It can be done, but it would be easier just to swap in the 2.4.
Whatever you want to do, your 3 easiest motor swap choices, just happen to be all great motors
03-20-2009, 10:53 PM
The 2.4L has major issues, I can see why you wouldn't want another one.
Swapping in a 3.4L will be much easier than swapping in a 2.2L, as long as you use the same year engine.
You will need 3.4L engine, trans, coolers, maybe drive-axles, PCM and BCM (VINs must match) Maybe more, but not as much as a 2.2L would need.
Unfortunately, by going to the 3.4L you will have LIM gasket issues and water pump, but that's better than a 2.4L and oil pump or bearing or water pump problems.
03-20-2009, 10:57 PM
How is a 2.2L swap more intensive than a 3400 swap?
The 3400 needs a 4T45E transmission, whereas the 2.2L uses the same transmission as the 2.4L.
does it really?
03-20-2009, 10:59 PM
just swap in a vvt 3900
03-21-2009, 01:29 AM
Fail! The bell housings are different between all 3 engines.
03-21-2009, 01:30 AM
Doesn't matter, a bellhousing doesn't make the trans a 45 or 40.
03-21-2009, 01:45 AM
That may be partly the case, but in regards to an engine swap they're not the same.
Just like for example the 4L60-E came on everything from a 2.2, 3.4, 3.8, 4.3, 5.7, etc... But they're not the same.
03-21-2009, 02:07 AM
Personaly I would stick with the 2.4L cause its freakin sweet.
1999, RED Alero GX
03-22-2009, 06:38 PM
Boost Guru
Right, but if you're swapping a 2.4 for an Eco, you still need to swap the Eco's 4T40E transmission in with it.
03-22-2009, 06:44 PM
Oh, k.
03-22-2009, 07:11 PM
Swapping in another 2.4 is your simplest solution if you want a new engine.
No matter what, you are going to need to do more work, buy more parts, and most likely spend more money if you swap in a different engine.
What is your reason for wanting to swap in a 3400 in the first place?
03-22-2009, 08:51 PM
Stick to the LD9...you'll save more money than swapping over to another engine.
