Old 07-29-2009, 11:41 AM   #1
twagn
twagn's Avatar
twagn is on a distinguished road
LIMG Leak
A mechanic informed me of the bad news today but he "says" most of the leaks he's repaired (@40) don't leak coolant into the crankcase. True or false?
Thanks
2k, GL, 3.4
twagn is offline   Reply With Quote
Old 07-29-2009, 11:46 AM   #2
eventually they do. he might just be catching them before they progress to that point.
Old 07-29-2009, 11:48 AM   #3
mine did, with NO external leak. mine was so bad i poured the entire rad into the crank in like 10 minutes.... i did it it was easy. if you have watery oil, before you put it back together, clean the lifters, or the same thing will happen to you as to me, it held my valves open enough to simulate no compression.
Old 07-29-2009, 12:20 PM   #4
zzyzzx
zzyzzx's Avatar
Exactly what does (@40) mean? I'm sure it's some sort of typo.
Old 07-29-2009, 12:28 PM   #5
i'm pretty sure he means @ = approximate.
to clarify:
@ = AT.
~ = approximate
from a symbolic standpoint.
Old 07-29-2009, 01:00 PM   #6
AGT
AGT's Avatar
to clarify:
@ = AT.
~ = approximate
and 40 meaning the mechanics age...i think haha
Have a good day
Old 07-29-2009, 01:02 PM   #7
approximately 40x hes done the job.
just throw in random mechanic facts..
I need my limg fixed. My mechanic says so. Hes 40yr old, likes walks on the beach. It isn't leaking into my crank case. Is it common for it to happen? Hes also a scorpio
Old 07-29-2009, 01:03 PM   #8
AGT
AGT's Avatar
Random fact: You ass...
So are you gonna have him do the fix....How much he quote ya?
Have a good day
Old 07-29-2009, 01:29 PM   #9
twagn
twagn's Avatar
He's repaired 40 lower intake manifold leaks and wants $800 to perform the deed. He says Dex-cool causes the problem to begin with. The car has 113k
2k, GL, 3.4
Old 07-29-2009, 02:07 PM   #10
It's not necessarily the fault of the dex-cool.. It's the combination of the type of plastic in the gaskets with the organic acids in the dex-cool.
Old 07-29-2009, 02:10 PM   #11
I would drive there and do it for $800.00.......
If I wasn't up to my ears in overtime hrs. right now.
Old 07-29-2009, 02:55 PM   #12
zzyzzx
zzyzzx's Avatar
I was thinking that the mechanic found 40 leaks in your intake manifold gasket.
Old 07-29-2009, 03:07 PM   #13
twagn
twagn's Avatar
Isn't dex-cool reformulated now? Which makes it better than the original? Anyway, He wants to use the plastic type gaskets and change over to green coolant. I don't think plastic gaskets are the best replacement from what I've read on this forum.
It's a very slight leak at this point but a leak none the less. I'm going to keep an eye on it for now cause I can't swing the $800 to have it repaired.
2k, GL, 3.4
Old 07-29-2009, 03:10 PM   #14
twagn
twagn's Avatar
You sure about that? I'm about eighteen hours from Denver
2k, GL, 3.4
Old 07-29-2009, 03:24 PM   #15
I made it to KY in just over 19. But it IS downhill....
Old 07-29-2009, 04:19 PM   #16
surreal_awakening
surreal_awakening's Avatar
surreal_awakening is on a distinguished road
Send a message via Yahoo to surreal_awakening
Just posted in another thread on the same topic....
http://wot-tech.com/shop/all/large-p.../prod_118.html
Use that, not the plastic ones.
surreal_awakening is offline   Reply With Quote
Old 08-03-2009, 05:56 PM   #17
twagn
twagn's Avatar
Put an add on Craiglist and found someone who will do the job for $300 and I provide the parts ...gasket set from wot-tech
2k, GL, 3.4
Old 08-08-2009, 09:35 PM   #18
buickboy71
buickboy71 is on a distinguished road
3400 Limg
If you drive to Jeff City I would do it for $250 if you provided the parts. I've done over 100 of these now.
buickboy71 is offline   Reply With Quote
