11-26-2012, 02:48 AM
Slow start... timing belt? (already changed plugs/wires)
2 part question
Around what mileage should the timing belt be replaced on the 3400?
And lately, my car has been slow to start (turning over a few times instead of just firing up immediately like she used to)
I just changed plugs/wires, thought that was the most likely culprit but still the same... what else could it be? (hence my first question)
1958 Super 88 Holiday Coupe
1970 Cutlass S
2000 Alero GLS Coupe
11-26-2012, 06:53 AM
first : there is no t-belt on te LA1... it's a chain... you should know what is is is you got those cars >> 1958 Super 88 Holiday Coupe & 1970 Cutlass S
second : defective plugs/wires causes misfires... not slow starting condition...
start with the obvious have your battery checked 1st, check all your positive and ground wires 2nd, and measure the amounts of amp that your starter draws when cranking...
You're Welcome !!
11-26-2012, 07:22 AM
Mine is doing the samething but I have the 2.4
11-26-2012, 08:50 AM
i had a similuar issue when i was running my 3400, i belive it was a stickey idle control valve, i just did a seafoam treatment to it and the engine ran like it was new, then a few months later i bent a valve trying to to a valve stem seal job and just tossed a 3500 in it instead
11-26-2012, 09:09 AM
You're Welcome !!
he may not be refering to how "fast" the engine turns over, but maybe how long it takes to start as in maybe a few extra cranks. i have seen a tune up help this problem before
STILL test the battery. also how about air filter and fuel filter?
11-26-2012, 12:17 PM
intake?
11-26-2012, 04:27 PM
in b4 manwhore says its the tranny  haha
11-26-2012, 06:33 PM
nah its gota be the tires
11-26-2012, 06:37 PM
put da aire in da tyres, yah yah yah , den it starts real goooouid yah yah yah, den check dem damm muffler berins dems a bich
11-26-2012, 07:09 PM
dont forget xenon headlight fluid, gotta check that monthly.
do you wait for the fuel pump to prime before you start?
11-26-2012, 10:38 PM
yah yah yah and da starder switch fluidddd
11-27-2012, 05:00 PM
If it is cranking and not starting and you smell some gas (maybe or maybe not) check into the fuel pressure regulator going bad.
11-27-2012, 09:04 PM
I also want to know if it's just turning over slowly just because it's cold (and if so try synthetic oil and check your battery's age).
11-27-2012, 10:44 PM
My first thought was battery
12-14-2012, 07:45 PM
Yeah this ^ it used to fire up in 2 or less revolutions, now it cranks awhile before starting
Battery was replaced less than a year ago but I guess I can check it anyway, but again -- it's not that its turning over slowly, just taking to long to start
Just changed the air filter when I did the plugs/wires (+ oil & filter et al)
Fuel filter is something I hadn't thought of though...
Thanks for all the replies BTW (I work retail so this time of year took me awhile to check back)
1970 Cutlass S
12-15-2012, 01:32 AM
Its the Tranny
12-15-2012, 09:39 AM
Haha I knew it!
OP, have you had any luck?
12-15-2012, 10:02 AM
Hahahaha
12-17-2012, 09:57 PM
Haven't had any time to check it out  just dealing with it for now
1970 Cutlass S
01-13-2013, 09:28 PM
prime the fuel pump a few times before starting by turning the key on for a few seconds and then back off, and doing this a few times. If this helps you have a problem with fuel delivery, which would probably either be a fuel pump wearing out or a problem with the regulator.
www.milzymotorsports.com
