Old 11-15-2013, 08:09 AM   #1
Hey Mike, if you see this, what WHP would you estimate on a MAF that's hitting 11,400hz up top bud?
Old 11-18-2013, 01:43 PM   #2
MilzyZ34
MilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond repute
Send a message via AIM to MilzyZ34
if using a stock MAF, that's about 48lb/min of air. I found Tim Kasczun's dyno run which is as close of a baseline as I can get, did some rough calculations to compensate for NA AFR vs boosted, drivertrain loss from blower, etc. My guess, 325 whp? No idea if that's right or not, but sounds about right. parasitic drag on the blowerloss isn't even linear, let alone predictable, atleast without knowing all the data on the blower.
www.milzymotorsports.com
MilzyZ34 is offline   Reply With Quote
