Old 12-06-2013, 02:41 PM   #1
03gxeco
03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute
do I need wheel spacers for 17x8?
Im going to get my wheels sometime this weekend. they are 17x8s off a bonneville which has close to the same offset as the alero. bonneville wheel.jpg That is the wheel im putting on the alero, close to the gagt wheels I have now but larger im hoping this will fill out my wheel well a little more and allow me to do the brake swap. I still have rear drums so i mean that will look stupid but im not going to do a rear disc swap for a long time if i ever decide to. I love the way the gagt rims looks on the car thats why i chose these ones. Anyway, I just need to know if ill need spacers if i use the OEM recommended 235/50r17 tire on these wheels when i install them.
2003 V6 gl coupe. Mods: cold air intake, Resonator Delete, GAGT muffler, GAGT torqued 5 spoke rims, grand am pre02mirrors ,cross drilled and slotted rotors by powerstop, 1999 hvac blue knobs
03gxeco is offline   Reply With Quote
Old 12-06-2013, 02:51 PM   #2
Well im sure you dont need them... maybe.
Most I would say is if the bore size isnt 70.3mm (I believe thats the alero bore) you will need spacers or will have to find a machine shop to drill em to that size.
Imo im not a fan. I would just get aftermarket wheels.
Old 12-06-2013, 02:55 PM   #3
03gxeco
oem quality > aftermarket looks . my opinion. lol.
Old 12-06-2013, 02:56 PM   #4
Thats fine. My statement was just an opinion.
Old 12-06-2013, 02:58 PM   #5
03gxeco
i know bud. I like your wheels but im getting these for a hell of a deal so I want to take it.
Old 12-06-2013, 02:59 PM   #6
Nothin wrong with that.
Old 12-06-2013, 03:01 PM   #7
03gxeco
just checked a bonneville forum, the hub bore is 70.3mm
Old 12-06-2013, 03:12 PM   #8
mfuller
You likely will need to use a small spacer if you go with a 235/50R17 tire.
If you use a 225/45R17 tire (to keep the PCM happy), then you might be okay.
Old 12-06-2013, 05:06 PM   #9
03gxeco
is a 225 going to be to small for the 8 inch rim?
Old 12-06-2013, 05:13 PM   #10
mfuller
No. I run a 225 tire on my 8" wide rims.
Old 12-06-2013, 09:16 PM   #11
ew
Old 12-07-2013, 08:33 AM   #12
mfuller
ew
Why ew?
A wider tire is heavier.
I can get great grip with a carefully-selected 225 tire.
Why install a bigger tire than you need? You're just hauling around excess weight.
Old 12-07-2013, 10:18 AM   #13
Lol Matt i think Billy was referring to the style of wheel not tire dimensions
If you go with the bonneville tire size it.will throw out your speedometer and if you lower the car it could rub on the fenderwell...
Old 12-07-2013, 12:35 PM   #14
eh. most wheels will throw it off. mine is off 2-4 mph...well was until I redid my gauge cluster and now its spot on cause I adjusted the needle.
Old 12-07-2013, 03:00 PM   #15
Lol Nate ... you.can adjust it in hptuners... paul recalibrated mine to account for.my 20's... I'll need him.to readjust for my new 18's to get it back on track though
Old 12-07-2013, 04:06 PM   #16
Exactly. Those rims are fugly in my opinion. Aftermarket > OEM "quality"
Old 12-08-2013, 12:19 PM   #17
WIALERO
WIALERO's Avatar
WIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these partsWIALERO is infamous around these parts
Send a message via Skype™ to WIALERO
mine do this to but its only 3mph for me but im screwed for now :/ i bought the aftermarket key set from a parts store and i have to change my tires to my winterset so i can get work and well the key broke so any opinions on where i can buy a sturdeyer key at? 1.25 i think they are
2004 olds alero R.I.P 242,500
Now searching for a new Ho!
He no crazy, he WIALERO!!
WIALERO is offline   Reply With Quote
Old 12-08-2013, 01:28 PM   #18
Go back to place they should give you one free since it broke...
Old 12-08-2013, 05:05 PM   #19
WIALERO
WIALERO's Avatar
I did the manager said I should order off eBay next time or Go to king motorsports down hereand get some there been 4 returns this week on them lol
