Go Back   Aleromod.com > Main Forums > New Member Introductions
Old 05-15-2014, 03:52 PM   #1
Savagejuggalo503
Savagejuggalo503 is on a distinguished road
2002 with blown head gasket
I'm new to this site so if this has been posted before please forgive.
My v6 3.4L blew the gasket and I'm stubbern so I'm going to try a rebuild has anyone done this and got it working?? Any advise to make the job easier and should I mod while rebuilding??
Savagejuggalo503 is offline   Reply With Quote
Old 05-15-2014, 04:03 PM   #2
I've rebuilt a couple 3400's and i have to say it's completely effortless, what makes you say the heads are blown? Do you have milky coolant?
Old 05-15-2014, 05:07 PM   #3
Savagejuggalo503
Yes no doubt milky oil was going through a gallon of antifreeze a day. I have watched videos of the 3400 sfi rebuilds and they look easy but friends and fam tell me that it won't run right after rebuild
Old 05-15-2014, 05:08 PM   #4
Mine ran perfectly fine for another 75ish~K Miles. The engine was still running strong when it went off to the yards.
Old 05-15-2014, 05:14 PM   #5
Savagejuggalo503
Mine is 150k right now I don't know how long it will take me to rebuild I get discount parts where I work and can get the parts for cheap
Old 05-15-2014, 05:44 PM   #6
Go for it dude, mine had 180k when i redid mine and it had like 275k when the rust finally got too bad to keep the car. My heads never went again and the car kept making good power.
Old 05-15-2014, 06:19 PM   #7
Yeah shouldn't be too bad. I never did any work on my car about 10 years ago, but that all changed when I realized who simple this motor really is
Old 05-15-2014, 06:51 PM   #8
Savagejuggalo503
Thanks that gives me a boost of confidence that I can get it done I can get the whole gasket set for $90 from my work so I think I can get a rebuild for less than a grand (mostly beer cost)
Old 05-15-2014, 07:23 PM   #9
The engine is basically a mini 350. It's a simple pushrod V6, you should be fine with a Haynes Manual and patience.
Old 05-15-2014, 08:09 PM   #10
Kalimaze
Kalimaze's Avatar
Kalimaze is infamous around these partsKalimaze is infamous around these partsKalimaze is infamous around these partsKalimaze is infamous around these partsKalimaze is infamous around these partsKalimaze is infamous around these partsKalimaze is infamous around these partsKalimaze is infamous around these partsKalimaze is infamous around these partsKalimaze is infamous around these partsKalimaze is infamous around these parts
Just replaced my heads and gaskets not bad at all. Just make sure you get the heads checked. Both of mine were cracked.
Kalimaze is offline   Reply With Quote
Old 05-15-2014, 09:23 PM   #11
Savagejuggalo503
Will do I feel like if I rebuild I should mod rather than stock
My friend has a v8 mustang I beat him off the line in the rain and feel like the 3400 is a great motor
Old 05-16-2014, 04:58 PM   #12
Yeah you could mod it up, but even with an entire top end rebuild, you are still going to need a tune.
Just don't reuse head bolts
