Old 01-29-2015, 01:09 AM   #21
Originally Posted by 03glgold View Post
While I don't know for certain, the fogs are powered by the low beam circuit from the switch, so they should stay on.
Im not sure of that, sounds solid. but if not it shouldnt hard to rig. I do not have them and when I put some on will not be a factory install.
If it does not work for them, all you will need to do is find the ground wire for them and tie it right in there. That will leave it with a path, just like for the lows, when you flip on the high beams, and still have normal operation of them.
Old 01-31-2015, 03:50 AM   #22
Nas Escobar
Nas Escobar's Avatar
Originally Posted by Papa Rad17 View Post
yep! I stuck that on there on several months ago... whenever I posted that I suppose, and no issues since. When the high beams come on, the low beams stay on as well. All other functionality is normal. I did this after disabling the DRL's as well, Being that mine is 99-02 they were on the high beams, I have never experimented with them enabled. Though in theory there should be no problem.
My DRL is on the turn signals, so I'm ok. Just want to have all 4 lights on when in high beam mode. I might try your idea when I fix my high beam at the stalk.
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
