Hey all,
I've got a 2003 Alero GL with an electrical problem that has started recently.
The car will start, run and drive fine. All of the critical systems seem to work. Headlights, turn signals, wipers, etc. The radio also works.
However, several of the systems inside the car have problems. The gauges, HVAC, Power Windows and Sunroof will occasionally not function. Today, the gauges would work, but the others systems wouldn't.
After driving around for a bit, everything started to work again, and things were fine when I shut it down a few minutes ago.
But now I'm concerned about driving around and getting suck with no A/C and no Power Windows in the middle of summer.
I found an old thread that may be similar here:
http://www.aleromod.com/forums/showt...switch+problem
But, there was no solution.
I also got a P0141 code, but I don't think this is related. I've been getting O2 sensor codes for a while now, but usually different ones.
Has anyone else experienced this problem and fixed it?
Thanks a lot!
