Originally Posted by bkathsalero
^^ just like what i said as a hint!! haha that does make it alot easier you'll get almost a foot more of line to work with, u got to realize that bolts get tight, you gotta use some force, bust some knuckles!!
Lol hard to do with a torx screwdriver (it's on a handle, like a normal phillips head would be).
Originally Posted by jabartram
undo the torx screw and pull the fpr out of the fuel rail. there is a 13mm nut holding the fuel lines against the block, remove it and the fuel lines will move further away.
I'll let you know how it goes
