06-26-2012, 12:28 AM
#21
Originally Posted by ronnysbray
Kendal which bulb type did you select?
DDM HID Kit, 35W, 9006, 8000K (Kit / Package) - directly from my order history
and sorry they were 55.30 shipped * 40 + 15.30 shipping/tax
06-26-2012, 12:30 AM
#22
Originally Posted by jawa
now get the euro ones for a even better beam patter
do you have a pic of euro headlights on an alero ? with or without HIDS either way is fine
06-27-2012, 05:19 PM
#23
ddm is the way to go for hids. always.
06-28-2012, 02:30 PM
#24
yep thinking about some for my highs just dont know if its really worth it since i dont see a need for my highs anymore after these
06-28-2012, 02:46 PM
#25
i got 35W 8000k lows in mine, its nice, never use my highs so didnt care to buy hids for it. imo, i wouldnt worry about it, lows are good enough to where you really dont need the highs anymore lol
Originally Posted by Oldsnut
Originally Posted by tipnitty
06-29-2012, 12:44 AM
#26
I had them in both of mine. if your going to put them in both get the harnesses. if you get 55w anyway. im sure about 35w kits.
07-02-2012, 01:30 AM
#27
I ordered mine today
"Horsepower sells cars,Torque wins races." ~Carroll Shelby.
2004 oldsmobile alero gl1 sedan, cold air intake from chrome intakes, catback exhaust, ceramic brakes and cross drilled rotors.
Future mods are going turbo charged, paint, new exhaust system, converting rear brakes to discs, and hopefully a 6-speed tranny swap. Not exactly in that order.
07-20-2012, 12:22 PM
#28
those look nice.
04-16-2013, 02:35 PM
#29
question
I saw the bulb color, wattage and type for installing HID what about the other items like mounting brackets, hid harness, error eliminator and adapter cables do I need any of them?
04-16-2013, 02:51 PM
#30
just the hid kit
04-16-2013, 05:56 PM
#31
help post
Thanks I apprecaite the post not bad for $39.95. Kit looks pretty straight forward. Now if someone wanted high and low for a 2001 alero gold package what would they need.
04-16-2013, 06:06 PM
#32
9006 and 9005 hid kits, but the problem with using hid on the high beam is that the flicker would render them useless for about 10 seconds and the fact that HID lights are not made to be turned on and off as constantly as high beams are.
You would be better off using HID lights for the low, and HIR bulbs for the high's.
Check this link. http://hirheadlights.com/
Basically, it's a brighter halogen that is designed to be just as bright as a 3500 - 4000k HID. That's the optical range where you actually have visibility, and the light won't fade when it rains.
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
04-16-2013, 06:14 PM
#33
Thanks alot for the help bud appreciate it.
04-16-2013, 06:42 PM
#34
make sure you remove the DRL's
04-16-2013, 07:54 PM
#35
I put HIDs in my first alero on the high beams. not worth it at all. Just wire up the low beams to stay on when you kick on the brights and put the HIDs in the low beams.
04-16-2013, 11:09 PM
#36
Thanks sounds like lows the way to go considering it's only $40. What are DLR's?
04-16-2013, 11:13 PM
#37
Daytime running lights, if they are active with HID's, it will make them flicker and destroy em.
There's a fuse under the hood (if you have 3400 motor) I'm not familiar with the 2.2 or 2.4, but you pull it and cut the fuse related to the drls and re install. Then your all good.
04-16-2013, 11:17 PM
#38
AHH crap I totally forgot about that. And yes I have the 3400 Thanks for reminding me of that.. Was that what the other guy was talking about when he said he followed smurfs install directions?
04-16-2013, 11:19 PM
#39
Umm maybe? I don't see anyone referring it, why don't you quote it for me.
04-17-2013, 01:52 AM
#40
2.2 had the fuse in 2003-2005. The others had to be removed by wiring. This of course is assuming that the wiring harness for the Alero and Grand Am are the same.
1996 Infiniti G20
