08-10-2011, 05:00 PM
#41
ya i have a maroon car also.
08-22-2011, 07:19 PM
#42
just call me "Doc"
Check out my alero!
Aleromod Showcase Video
09-11-2011, 08:32 PM
#43
just call me "Doc"
Check out my alero!
09-11-2011, 09:50 PM
#44
Looks good. What did you use to clean it?
I was thinking of doing mine black but I can't bring myself to spend the money to get a new gasket to replace the old one just to paint it.
2003 Alero 2.2 Ecotec Auto - Cosmo intake - cleared/painted headlights
09-11-2011, 11:23 PM
#45
I used a steel brush drill bit. The larger sized ones. But i used the same gasket. I researched this mod for over a week and a lot of people have used the gasket like 4x again. Its a pretty durable gasket. As long as you dont break it when you are prying the valve cover off, then you can deff use it again (provided it was in a good shape already) Just make sure when u are putting it back on, put some motor oil on ur finger and run it all along the gasket.
Cheap mod. Only like $7 for the paint.
(the tools needed I already had)
just call me "Doc"
Check out my alero!
12-26-2011, 01:40 AM
#46
Is it just pull the bolts around it to get it off? Iv been wanting to get mine painted but wasn't sure what all was involved in taking it off.
12-26-2011, 05:31 AM
#47
i think i used this thread
http://www.j-body.org/forums/read.ph...29034&t=329034
I had a steel brush that I used to take basically polish it
I had a handy dremel to reach the small parts.
then i used red engine enamel iirc. (you could use other stuff for better turnout like powder coat it)
but its real simple, just take your time when letting it dry.
Also, be careful when you put it on so that you dont get any chips in it.
When I was putting it back on i was kind of anal about torque-ing it to the correct ft/lb but I was told that it was just a valve cover and that just hand tighted plus a quarter of a turn will be fine
just call me "Doc"
Check out my alero!
12-26-2011, 10:42 AM
#48
Perfect link! Thanks, and I found the vid. Thanks.
02-21-2012, 12:00 PM
#49
Just curious how much hp im running right now with my current mods?
Any idea?
Intake, Pacesetter Headers, Magnaflow High Flow Cat, pacesetter dual exhaust
not tuned
Stock is 140hp
just call me "Doc"
Check out my alero!
02-21-2012, 12:38 PM
#50
intake +5
header +7
cat +2
catback +10
140 +24 = ?? ((hint~164)
your probably only seeing 135-145 to the wheels if your lucky.
get HPtuners and tune it, then (if HPT calculates it) figure your HP. there are multiple applications for laptops you can download that connect by usb to your obd2 that can read your hp levels and such. i had it done on my old saab and it was supposedly putting out 190hp
02-21-2012, 01:13 PM
#51
I am pretty sure 140 is the brake hp subtract 15% and that will be ur wheel hp the v6 may say 170 hp but it is really 140-150 horsepower to the wheels. get a supercharger then u will notice a big hp gain ya u are lucky to have 145hp.
02-21-2012, 05:40 PM
#52
Any idea?
not tuned
Stock is 140hp
im telling ya, pipe your intake like mine, eliminating that black box right onto of the throttle body makes a world of difference.
02-21-2012, 06:11 PM
#53
Needs Lowa!!
02-21-2012, 08:42 PM
#54
Originally Posted by kwhauck
Needs Lowa!!
waiting for the spring, then ordering H&Rs
just call me "Doc"
Check out my alero!
02-21-2012, 08:43 PM
#55
haha,
i did that awhile ago...
http://www.aleromod.com/forums/showthread.php?t=35330
just call me "Doc"
Check out my alero!
02-21-2012, 09:00 PM
#56
but when u get the springs u will need new struts.
11-12-2012, 12:27 AM
#57
How do you have 55watt In a stock headlight
11-12-2012, 08:54 AM
#58
The headlight isnt what the 55w melts it is only a problem with the fogs...a lot of people have55w hids some on stock harness some on adapter harness just depends on what luck they have
11-12-2012, 01:06 PM
#59
they are fine in the headlights. its purtting the 55w in a fog light that causes problems with to much heat.
11-12-2012, 01:09 PM
#60
You want them? I still got them...
just call me "Doc"
Check out my alero!
