Need some guru help on this before I drive myself nuts, maybe I just need a little clarification, even though I feel like I've done this one too many times.
I listen to a little bit of everything and need a good sub and amp package.
I'm still not sure what's worth going for, 2 10's or 2 12's or a single 12 or what on this one. I'm for some reason hellbent on 2 10's.
I've looked into amps
http://www.bestbuy.com/site/olspage....=1072286177806
http://store.yahoo.com/csexpo/p3rofopumoch.html
but I'm still not too sure on the conversions, if a dual channel is better for subs than the mono. If a mono is better for 2 subs or a 2 channel is.
Also the conversion rates of ohms and what subs are decent, mostly I see a lot of 250-300 rms on MTX audio, and there's a set of Audiobahn on sale, 450rms a piece
mostly the subs are from 50-80
and the amps in my range 170-240 or so
I can't figure out the combo, Mono are not bridgeable I'm correct, but a dual can hold more sub combinations at higher RMS ratings?
I'm not sure, if anyone can give me the best idea for a setup and products I'd like to know. As it stand right now I'm considering the Rockford/Audiobahn setup
Still not sure what will sound best, and what wiring combination would work correctly
