Old 03-08-2006, 03:09 AM   #1
HAZED
just installalled two 12 w3v2 in homemade box but every time i raise it up they start to pop. is the box 2.0 cub
Old 03-08-2006, 01:51 PM   #2
King Asoka
King Asoka's Avatar
You neeed to tell us about your system and install.
my geuss is that you are overpowering the subs or clipping the amp
Old 03-08-2006, 03:57 PM   #3
wrightie
wrightie's Avatar
wrightie has a little shameless behaviour in the past
my system did the same when i installed. My amp (500/1) will run at 1.5-4 ohms. the way I had it configured it was runing at 1 ohm and it would clip or distort every time i would try to turn it up. I bet this is you problem. Look at how you have them wired. good luck.
wrightie is offline   Reply With Quote
Old 03-12-2006, 10:59 PM   #4
HAZED
yes wired in parellel is what i have them also i have a 500/1 jl audio amp
Old 03-13-2006, 10:22 AM   #5
battistoni21
battistoni21 is an unknown quantity at this point
Send a message via AIM to battistoni21
yeah something seems wrongf there, i'll ask my friend, he's a freak with audio stuff, i'll let you know what he thinks it is.....
battistoni21 is offline   Reply With Quote
Old 03-13-2006, 09:08 PM   #6
mikegett
mikegett's Avatar
Do you have the JL amp sensitivity on the wrong setting? There is a switch for low input and high input sensitivity from a HU.
Old 03-14-2006, 10:35 AM   #7
HAZED
i have it low.. i was thinking it was the box
Old 03-14-2006, 06:55 PM   #8
mikegett
mikegett's Avatar
What HU do you have? If you are using a 4 volt or higher aftermarket the amp will clip at low volumes. The same could be true if you are using a Line out converter. They tend to max as high as 8 volts.
Old 03-14-2006, 08:51 PM   #9
HAZED
alpine its 2v
