Old 03-13-2006, 05:43 PM   #1
Menace
@Kutztown University PA
Menace's Avatar
Menace is an unknown quantity at this point
Send a message via AIM to Menace
Well I have a problem. My key wont come out of my ignition. It will turn all the way on and to the point that it runs off the battery but wont come all the way off. I just unplugged my batery to try to reset the carputer. Whats going on here?
Alero is sold!
2007 Scion tC in driveway!!
Stuff for sale
http://www.aleromod.com/forums/showthread.php?t=13919
Menace is offline   Reply With Quote
Old 03-13-2006, 05:53 PM   #2
did you do any console mods?
-And-
(de de de question) is the car in park?
Old 03-13-2006, 05:55 PM   #3
Menace
Menace's Avatar
I was working on my console a bit and my car is in park.
Alero is sold!
Stuff for sale
Old 03-13-2006, 05:57 PM   #4
Str33tRacer
wait.... you're cars key is stuck in the ignition right now?
Old 03-13-2006, 05:59 PM   #5
ok, simple to fix, go back out into the car, and lift up the center console part. The console part where the ashtray part meets the radio bezel.
left that up like .5" (just pop it up a little) then your key should come right out.
EDIT :
Wanted to post that for you to read before i gave my story... lol
i had this problem like 8 times, before i got pissed and sat there, checking EVERYTHING trying to figure out wtf is wrong w/ my car. I always figured it was a fluke thing, because if i messed with it, it'd let go of my key.
The problem is there is a small guy wire sensor next to the shifter... if you push that console part back down to hard, something hits that wire and doesn't allow it to go all the way back against the sensor, telling it to disengage the key.
Old 03-13-2006, 06:00 PM   #6
Menace
Menace's Avatar
lemme go check
Alero is sold!
Stuff for sale
Old 03-13-2006, 06:07 PM   #7
Menace
Menace's Avatar
Didnt work
Alero is sold!
Stuff for sale
Old 03-13-2006, 06:13 PM   #8
King Asoka
King Asoka's Avatar
It's an easy fix, when you reinstalled your shifter you must have installed it too low.
When the shifter is off, Im assuming u have an auto, you can see the black metal and the white plastic part of the shifter. When you reinstall your shifter handle and it is pushed down to far it will depress the white plastic piece, which is the shifter. If this is pushed down it will not let your key come out of the ignition, its a safety feature.
So when you reinstall it make sure it is just sitting on it and not depressing it.
I dont know if you can follow what im saying, so let me know and ill try to clarify.
Old 03-13-2006, 06:23 PM   #9
Menace
Menace's Avatar
Yah I understand what your saying but that wasnt it. Tried it already and just took off the whole shifter. Nothing still!!
Alero is sold!
Stuff for sale
Old 03-13-2006, 06:53 PM   #10
Menace
Menace's Avatar
K just to put in some more details. The cars in park, the shifter knob isnt on to tight, the center console isnt to tight, the key wont go out of the battery thing. Like it wont even go to off.
Alero is sold!
Stuff for sale
Old 03-14-2006, 07:31 AM   #11
Menace
Menace's Avatar
My dad said its probubly my ignition switch. He said he thinks its just a plug and play type of thing. Is that right? Do we have a how to about installing it?
Alero is sold!
Stuff for sale
Old 03-14-2006, 07:49 AM   #12
AGT
AGT's Avatar
Did you install a new ignition switch? Did you try restarting the car and then shut off?
Have a good day
Old 03-14-2006, 08:12 AM   #13
Menace
Menace's Avatar
Didnt install a new ignition switch yet. Yes I restarted car but was the same.
Alero is sold!
Stuff for sale
Old 03-14-2006, 11:02 AM   #14
AGT
AGT's Avatar
The only other thing I could think is needing to put graphite lube in it but you can't do that with the key in there...I am gonna try something...BRB
okay...so does the key stop between the ACC and OFF position or ?
Have a good day
Old 03-14-2006, 11:31 AM   #15
AftermathAlero
undoing the battery cables trying to reset the car.. will not take the key out. You prolly have a bent key. Just wiggle and jiggle it. If not.. u can buy a whole new key assembly. Its like 350 bucks from gm w/ a new key and all.
Old 03-14-2006, 12:03 PM   #16
AGT
AGT's Avatar
and make sure when you are trying to turn the key to OFF that its pushed in.
Have a good day
Old 03-14-2006, 12:08 PM   #17
Str33tRacer
i know when i try and start my car its really picky... it has to be turned right before its fully put in. and when pulled out its just the opposite
Old 03-14-2006, 03:13 PM   #18
King Asoka
King Asoka's Avatar
it could definatly be the ignition switch, I had the same problem. Mine was fried. To get at it you have to remove alot of the dash. If your a do it your selfer im sure you can do this. other wise take it to a pro. the switch is cheap, its the labour that will cost. Im guessing $200 or so.
Old 03-14-2006, 06:37 PM   #19
Menace
Menace's Avatar
I brought it to the olds dealership and told them it was my ignition because I was sure of it. 141 dollars later im right
Alero is sold!
Stuff for sale
Old 05-30-2006, 10:11 PM   #20
ThePrettyPhysicist
Aleromod Battery Guru
ThePrettyPhysicist is an unknown quantity at this point
Send a message via AIM to ThePrettyPhysicist Send a message via Yahoo to ThePrettyPhysicist
i just want to say that that makes me laugh because 3 or 4 months ago, I did that. I must have called my entire family to see why I couldnt get the key out of the ignition (I was at work). It was the same day that my fiancee was getting my Fiero towed from school because the fuel pump went, so he was irritated to begin with. Needless to say, he stopped by and came into the store with my keys and simply said "hey dumba$$, you didnt put it in park". i felt like a jerk. i can blame it on being blonde though 0
The Pretty Physicist
2004 White Alero GL - "Raccoon Killer"
1987 Burgundy Fiero GT - "Mr. P-Body"
1986 Silver Fiero SE - "Half Pint"
ThePrettyPhysicist is offline   Reply With Quote
