Old 02-25-2004, 11:44 AM   #1
brad_galles16
I am looking for some sound dampning material to put in my trunk and in my trunk lid. Should I use Dynomat or some other material?? And how hard is it to put in with two people?? And do I have to take out my carpet or can I put it under my carpet??
Old 02-25-2004, 01:40 PM   #2
99blackalero
i used dynamat and put it under the carpet, and you dont need two people to do it, just make sure you follow the instructions
Old 02-26-2004, 01:16 PM   #3
sparky009
you cold do it yourself it does not take to long all you need is a heat gun and a roller just dont buy the offical dynomat roller go to home depot and buy it lots cheaper....
you will need to put it under your carpet just roll it up into the back seat...
Old 02-26-2004, 01:56 PM   #4
brad_galles16
Also....there is something banging in the middle of the trunk. It is not really a rattle, just annoying banging sound. Is it the 3rd brake light?? Thanks
Old 03-17-2004, 03:39 AM   #5
niral622
niral622 is an unknown quantity at this point
yeah, I heard some people talking about taht once...I think its that flat above the number plate that rattles. Try pumping some greatstuff expanding foam ($5 a can from Home Depot) into that area--I used that stuff in my friend's blazer and it sounds 100% clean, no rattles anymore...just make sure you're careful not to spill any on the paint of the car or anywhere where it'll be seen, doesnt come off too easily (at least not off plastic) <_<
http://www.dow.com/greatstuff/products/index.htm
I used "Gaps and Cracks" by the way. :thumbsup:
2003 Black GL - Sedan and No sunroof
niral622 is offline   Reply With Quote
Old 03-17-2004, 03:44 AM   #6
niral622
oops forgot to mention that I used that Gaps and Cracks in the metal area of his trunk....you should use the "windows" one....here's a similar post:
http://invision.aleromod.com/index.php?showtopic=2026
Old 03-17-2004, 03:52 PM   #7
vulgar
vulgar's Avatar
vulgar is an unknown quantity at this point
Send a message via AIM to vulgar Send a message via Yahoo to vulgar
I dont know if Id recommend using "great stuff" i think it has a tendency to expand and contract with changing temperatures...to what degree I do not know. If you insist on using spray foam i recommend the kind that the company "DAP" makes as this stuff is easy to remove and doesnt turn as hard as a rock like the great stuff will...so if you do overspray or get it where you dont want it its easy to remove. As far as that plastic piece above the license plate that says alero on it I recommend just taking some packaging foam and putting it behind it. When the subs hit in your trunk this piece flexes out and then vibrates against the piece behind it, making it flex out slightly by using something such as foam, spray foam etc. will cure a lot of that problem. Also putting dynomat behind your license plate can keep that from rattling if it does at all.
A.K.A. sepultribe66
the alero will be missed :o(, but I love the mazda6 :o)
vulgar is offline   Reply With Quote
Old 03-18-2004, 10:43 PM   #8
sparky009
I heard of this stuff called Brown Bread and it is suppose to work verry wel it is almost half the price of Dynomat but when I buy some I will let you knowhow it is.......
Old 03-19-2004, 12:17 AM   #9
niral622
yeah, you can get that stuff from www.b-quiet.com....I got some of the b-quiet cheap stuff and even that is equal in performance to the dynamat (I think so at least)...the brown bread is thicker and has higher sound dampening spec ratings than both the b-quiet and the dynamat so I figure that must be awesome
Old 03-20-2004, 12:22 PM   #10
xsavyor1
xsavyor1 is an unknown quantity at this point
From My Exp. They are all about the same.
TEAM PRODIGY-TEAM CROSSFIRE-TEAM XS POWER
WWW.TEAMPRODIGY.NET
WWW.CROSSFIRECARAUDIO.COM
2010 BASS RACE WORLD CHAMPION 140.0DB - 149.9DB
2009 Bass Race World Champion 140.0-149.9db Class
xsavyor1 is offline   Reply With Quote
