Old 02-28-2004, 09:43 PM   #1
boarder211
Hey peeps...
Got a question for you all. I'm bridging my amps into each of my subs right now, but they're not handeling the power all that well. If I was to go with dual voice coil subs, what would this do to the peak power of my amps? I know that I couldn't run them in parallel, but what about running them in series for a combined resistance of 8 ohms?
Any thoughts would be appreciated...
Thanks in advance!
Oh yeah... for the record, I'm usint 2 MTX Blue thunder Pro amps... currently running at 300W bridged each... and I'm looking at a set of Alpine type R, 12"'s.....
Old 02-28-2004, 10:32 PM   #2
99blackalero
most subs run best at 4ohms and 2 ohms...most amps will put out more power at a 2 ohm load , meaning running the subs parallel down to a 2 ohm load..or running them at a 4ohm load...if you have an 8 ohm sub bridged on one amp, then youre not gettting the full power to the sub, they're meant to run in a multiple sub set-up
Old 02-29-2004, 09:18 PM   #3
AleroSS
Go with the Type R's Scott, you wont regret it, and lemme know what size and such and I can prolly get you an awesome deal if you dont wanna do it RIGHT now...
